12-08-2011, 10:23 PM
Flow Illustrator car templates!
Originally Posted by KamperBob
It would be great if the templates were available to others as a starting point for further fiddling, along with the parameters used in these runs.
If you don't have Flow Illustrator download it here. PC only at this point. Be sure to set Incoming Velocity to 120 and Viscosity to 45.
Let's start here.
*I have made every effort to make these accurate, including the underbody. Though I have traced them over blueprints, they will not be exact.
1988-1994
Suzuki Cultus/Swift
Geo Metro 3dr hatchback
1988-1991
Honda CRX
1969-1978
Nissan Fairlady S30
Datsun 240Z/260Z/280Z
1964-1966
Ford F100 styleside shortbed
1988-1992
Ford Probe, modified with grille blocks, air dam and partial belly pans
TO USE THESE:
Save them to your computer. Open that file in a program like MS Paint (it will be a JPEG-unusable in Flow Illustrator). Make your modifications. Save as 24 bit Bitmap (BMP).
If you'd like a side view of your car, let me know the year, make and model, number of doors etc. and I can whip it up for you.
For help with the shape of kammbacks and boattails, scale this aero template so the ground is at the ground plane and the top of the template is at the highest point of your car.
Like this:
More information here.
The Following 6 Users Say Thank You to Sven7 For This Useful Post:
12-08-2011, 11:04 PM
To get the Civics out of the way
EF 1988-1991 hatchback
EG 1992-1995 sedan
EK 1996-2000 sedan
EK 1996-2000 hatchback
EM2 2001-2005 coupe
ES1 2001-2005 sedan
FA5 2006-2011 sedan
Cheers
The Following 2 Users Say Thank You to Sven7 For This Useful Post:
12-08-2011, 11:31 PM
Three more. This is all for tonight.
Oldsmobile Aerotech Long Tail c.1992
1934 Tatra 77A (two headlight version)
1987-2007 Peterbilt 379 (I'm not sure if the underbody is correct)
The Following User Says Thank You to Sven7 For This Useful Post:
12-09-2011, 09:05 AM
I downloaded it, have to read how to use it, might never use it at the rate I adapt to new things though.
12-09-2011, 09:36 AM
Can you do the 94 Toyota Carrola sedan? I just need a picture with the aero templet overlayed. I just cant figure out how to do it.
12-09-2011, 11:43 AM
Recreation Engineer
Validation
New thread - good idea.
I'm looking forward to downloading the standalone version soon. For now I'm on dialup low-band so that's have to wait. But, once I get a round tuit I'd love to run Phil's template and a cylinder as baseline geometries for reference. In the real world first simulations validate the modeling tools; then experiment with different geometries. Anyone else game for this? (wink)
12-09-2011, 01:36 PM
It's super easy.
Hit enter, 0, enter. Type in the full location of the file, for instance, c:\users\john\desktop\carpicture.bmp. Make sure to use backslashes.
(If you open the folder in Explorer/My Computer you can see the file location at the top)
Press enter. Set the top (or left) slider to 120, and the other to 45.
Done!
To exit or open a different file, close out of the window you typed in.
You can use a free program called GIMP to overlay things, but it takes a little getting used to. I have Photoshop though so that works even better.
Toyota Corolla 1991-1995 sedan
Oof, I feel sorry for you using dialup!
Feel free to run whatever you want and report back with results!
12-09-2011, 11:59 PM
By the way if anyone wants to make their own, I get most of my blueprints from The-Blueprints.com - The largest free blueprint collection on the Internet but also get a few from Flickr when people scan in old spec sheets. Blueprints for things like the F100 are hard to find.
The Following 3 Users Say Thank You to Sven7 For This Useful Post:
12-10-2011, 07:51 AM
#9 (permalink)
Any chance you could do the 2000-2006 Honda Insight? It is similar to the CRX but smoother. You can find an outline drawing at this location:
InsightCentral.net - Encyclopedia - Honda Insight Scale Drawings
I'd love to give it a try!
Reason: addition
12-10-2011, 12:41 PM
#10 (permalink)
Aero Deshi
How's This Jim? Insight Silhouette. 600 x 300, Flow Illustrator ready.
The Following 3 Users Say Thank You to ChazInMT For This Useful Post:
