Old 07-17-2008, 01:33 PM   #51 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
where are you guys getting these bitmaps of your cars?
Old 07-17-2008, 02:26 PM   #52 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
We make our own bitmaps. Find an image, pop it into some image editing program and delete non-car (but make sure to preserve the ground level to simulate the tires height).
I've done my xA (haven't posted it) and was working on that Prius.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-17-2008, 04:12 PM   #53 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
2008 Prius
Re = 2465148 (calculated for 55mph)
dt = 0.01
length = 30sec
cutoff level = 0
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 07-17-2008, 05:58 PM   #54 (permalink)
Nerdcycle - '81 Honda CM400E
Motorcycle
90 day: 61.16 mpg (US)
Trouble - '06 Kawasaki Ninja
90 day: 74.69 mpg (US)
Edna - '13 Nissan LEAF SV
Last 3: 133.3 mpg (US)
Tank - '20 Ford Expedition Limited
Last 3: 17.4 mpg (US)
One thing I'm noticing on these that they're going to be pretty inaccurate if you don't have a belly pan, since all your bitmaps have smooth bottoms.
Old 07-17-2008, 06:25 PM   #55 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
extragoode -
I did an approximation with some random "bumps" on the underside and didn't see much of a difference. I'll upload it later tonight so you can see.
CarloSW2
American Solar Energy Society
Old 07-17-2008, 07:58 PM   #56 (permalink)
- - '10 Toyota Prius III w/Navi
Hi azrael...,
Ooops..
Old 07-17-2008, 08:03 PM   #57 (permalink)
Hi azrael...,
Thanks for the Prius model.
The flow off the top, and off the bottom look very balanced. Possibly there is more flow coming up from below, and going turbulent. My car always has a dirty rear window undeneath the hatch spoiler. That seems to support the model results. Possibly a linear difusser, and a shallow angle might help that.
The car has very poor flow out the wheel well vents. And the hatch fogs up easily, and takes along time to defog. So, this also supports that the flow from underneath the car is stalling.
Old 07-17-2008, 10:41 PM   #58 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
here is the areo CRX as it sits in its current state..
Old 07-17-2008, 10:58 PM   #59 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
So other than being interesting in a lava lamp sort of way, how do you interpret the video to determine what is a lower air resistance?
Less red is better?
Less movement (wave action) is better?
Both?
Nissan Versa Aeromods
Old 07-17-2008, 11:23 PM   #60 (permalink)
Veggiedynamics
Im not positive but yes i think your right less red and less wavey the better
air dam, air flow, simulation, spoiler, wind tunnel
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
