Old 07-06-2011, 07:11 AM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
meh, not critical is it. What does the instant/tank screen show?
Old 07-06-2011, 07:15 AM   #12 (permalink)
Hmm not sure, I will go and have a look when I double check the numbers.
Old 07-06-2011, 09:22 AM   #13 (permalink)
version 0.86. The picture on the first post is the instant/tank screen.
Old 07-06-2011, 09:31 AM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
Oh well, that is not the instant/tank screen in the first post, just the tank screen, but let me know if resetting it helps anyway or if there is a discrepancy between the instant/tank and the tank screens.
http://ecomodder.com/wiki/index.php/..._and_Functions
Old 07-06-2011, 09:40 AM   #15 (permalink)
MPGuino - EcoModder
Oh yes, Sorry, wasnt paying attention.
Before they reset the instant/tank and tank screens matched.
Im going on a long ride tonight so I will keep everybody updated.
On a side note, I sometimes turn my engine off at traffic lights, I notice that even after 2 minutes or so the current trip stats re-set when I restart.
Is there any way to avoid that?
Old 07-06-2011, 09:53 AM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
Not sure there, if you left the timeout set to 7 minutes and it is resetting after 2 then it might be a power glitch. Double check your timeout setting in the setup.
Old 07-06-2011, 10:56 AM   #17 (permalink)
It only does it when my kill switch is used, and only reset the current trip the tank info stays, very odd, will duoble check my timeout period.
Old 07-08-2011, 03:41 AM   #18 (permalink)
Right, I sorted the timeout, it was set way to low, becuase I though it was milliseconds
After a reset on the power supply, it was showing the correct tank mpg for about 30 miles , then it dropped down to 0.3 and it has been slowly climbing up
Any idea?
Old 07-23-2011, 07:31 AM   #19 (permalink)
Right, it appears as though when I go over about 78 tank miles that the tank mpg resets back to a very low number,
Any idea?
Old 07-26-2011, 07:42 AM   #20 (permalink)
Bump, any ideas?
I cant figure it out
