06-09-2014, 04:20 PM
DieselMiser
forcing yourself to save fuel
Cockeyed.com has an interesting concept for saving fuel. Always drive with a low tank to force yourself into driving efficiently.
Gas Rationing
06-09-2014, 04:43 PM
Rat Racer
4. Don't go to the store for a single item; combine errands.
Only buy a few gallons of gas at a time.
Does this guy set his alarm clock 10 minutes ahead to "trick" himself into thinking he's late and has to get up?
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
06-09-2014, 05:06 PM
0.29 Cd and decreasing
This testing doesn't even work because he has two different driving styles depending on how how filled his tank. If he filled 5 gallons he would drive more conservatively, while when he filled the tank up full I'm sure he'd drive normally.
For him to be able to say that 5 gallon fill-up gets better mpg the driving styles would have to be the same. It shouldn't be any more difficult to drive conservatively when he has a full tank.
I get what he means by having less gas in the tank would cause him to watch the tank and drive easier, If it ends up working for him, the money he saved in gas he's just going to put back in the vehicle by buying a new fuel pump because he burnt out the one in his vehicle.
06-09-2014, 05:46 PM
DieselMiser
His point is having less fuel in the tank forces him to drive more economically. Sort of like putting a big spike on the steering wheel would tend to make you drive more cautiously.
The Following User Says Thank You to ConnClark For This Useful Post:
06-09-2014, 06:23 PM
I had a friend who's wife insisted she got better mileage on the top half of the tank. Because, it took longer to drop down to half than from half to empty. So she always filled up at half tank because of this discovery.
I tried to explain a nonlinear fuel gauge....I gave up!
The Following User Says Thank You to doviatt For This Useful Post:
06-09-2014, 07:16 PM
College roomie always did that couple gallons/couple dollars "fill" B.S. for the same stated reason. Currently know a guy that chronically only has a few gallons in the tank and only puts $5 or $10 worth in.
Both of them spend a LOT of time at gas stations.
Gas tank games.
06-09-2014, 07:38 PM
Too busy for gas stations
Turtle - '92 Honda Civic Vx Team Honda 90 day: 67.09 mpg (US) Rolla - '10 Toyota Corolla Le Beast - '91 Chevy V2500 Bus - '01 VW Eurovan MV Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous 90 day: 53.09 mpg (US) Cal - '68 Ford Mustang GT/CS
how about a big spike on the gas pedal?
Shooting for 600 miles of range at 65-70 mph out of a vx.
06-09-2014, 10:17 PM
Here are some time-tested ways to save gas:
1. Get a newer, smaller car.
I stopped reading after that.
The Following 3 Users Say Thank You to cbaber For This Useful Post:
06-10-2014, 03:26 AM
#9 (permalink)
I get his point but it's still possible to force himself to have that mindset when he has a full tank
The Following User Says Thank You to tvbd56 For This Useful Post:
06-10-2014, 04:05 AM
#10 (permalink)
Anyway, with a half-tank there will be less dead weight on fuel to haul around
