01-27-2010, 07:13 AM
Ford claims new 6spd increases FE up to 9%
Apparently they are using a 6 speed manual and a 6 speed automatic. The article only claims that the auto gets the 9% though. From the rest of the article though, the new Focus is shaping up to be a nice car.
The updated 2.0L engine will be mated to either a 6-speed manual or a new 6-speed dual-clutch automatic transmission. Dubbed “PowerShift,” the new line of small-car automatic transmissions can reduce fuel consumption up to 9%, the company says.
New Ford Focus Outclasses Current U.S. Model
The Following User Says Thank You to Daox For This Useful Post:
01-27-2010, 08:01 AM
Now, if they give both the manual and the auto nice, tall gearing, and only off cruise (throttle?) control on the automatic!
01-27-2010, 08:31 AM
aero guerrilla
The auto probably has an ECO setting in its software to change gears at lower rpm. If a normal auto had similar (many do), then that would give 2%-5% savings over "normal" mode.
...beats walking...
...or, conversely, how about having the ECU provide driver-switchable "ECO" and "PWR" control settings over the transmission?
01-27-2010, 12:56 PM
The "Automatic" is a computer shifted manual, thus the 9% savings and the term "power shift" being used to describe it. I've seen it and lust after it. It is also tiny and very light compated to any manual or automatic I've seen. I believe this was developed with a German company, I think Getrag?
01-27-2010, 01:34 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Not surprising, Ford seems to be pointing their FE attempts toward their auto transmissions, especially in the Focii.. in fact, some auto Focii already get better FE than the manual versions on the highway. (EPA)
01-27-2010, 01:36 PM
Gas Mileage of 2002 Ford Focus
The Wagon models reflect it in City mileage at the bottom of that chart.
01-27-2010, 06:08 PM
Pokémoderator
Tygen1 -
Yup (from URL posted by Daox) :
Gone is the aging 140-hp 2.0L Duratec DOHC inline 4-cyl. that powers the current Focus. In its place will be a new 2.0L direct-injected I-4 with twin independent variable camshaft timing that is expected to generate at least 155 hp while also providing improved fuel economy.
Ford says a version of its turbocharged EcoBoost D1engine eventually will be offered on the Focus.
Ford’s PowerShift transmissions, developed with German supplier Getrag GmbH & Cie KG, essentially consists of two manual transmissions working in parallel, each with an independent clutch unit.
In comparison, the current North American Focus is available with either a 5-speed manual or 4-speed automatic transmission. Ford says advanced 6-speed transmissions such as PowerShift will be offered on nearly its entire vehicle lineup by 2013.
CarloSW2
01-27-2010, 07:48 PM
#9 (permalink)
Driving the TurboWeasel
Any of us with a manual could still slay the automatic's FE around town. Steady-state highway cruising is where it may have an advantage. You can't beat the FE of engine-off, though!
2012 Chevrolet Cruze Eco 6MT
01-27-2010, 07:58 PM
#10 (permalink)
Additionally it has a coast down feature that disengages the clutch to allow you to coast further with just a tap of the break, so theoretically you could put in a kill switch that kills the injectors and signals the computer that the brakes have been activated. EOC in an ATX !
