Old 12-11-2012, 03:22 PM   #41 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by Beau View Post
Funny, my first car in 1975 was also a 66 coupe w/straight 200ci 6cyl.
Oh, there is a great website mostly dedicated to the 200ci six.
wow!!!
ok, mine was a baby blue w/ auto. It was the 'sprint' package.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-11-2012, 03:54 PM   #42 (permalink)
Originally Posted by mcrews View Post
wow!!!
Mine was 1976 Corvette Firemist Red, with gold pearl.
Mostly stock, C4, some suspension upgrades, Appliance wheels, and, of course (for its day) a ridiculous stereo.
Old 12-11-2012, 04:07 PM   #43 (permalink)
mcrews's Avatar
By the time I sold it:
Clifford headers
into 2.25 single pipe in
1 3/4 dual out muffler, into GT tips (sounded like a straight six jags!)
lowered front A-arm (shelby specs)
air shocks in rear w/ individual fill lines.
Addco rear sway bar. Nylon bushings front and rear.
Battery in trunk.
AM/FM/CB Pioneer radio.
Cruise control
THIS IS THE BEST>>>>>> a led digital odometer/mpg gauge
ECO MODS PERFORMED:
First: ScangaugeII
Old 12-11-2012, 04:48 PM   #44 (permalink)
Ruby - '91 Ford Mustang LX
90 day: 21.09 mpg (US)
Dusty - '03 Volkwagen Passat
Stella - '04 Saab 9-5 Aero
Originally Posted by nj636 View Post
with 24# injectors?
Yes the 19s would have been sufficient but I went with the cobra 24s for a Lil extra room for tunning.
Old 12-12-2012, 07:39 AM   #45 (permalink)
EcoModding Observer
Civic - '98 Honda Civic DX
90 day: 45.83 mpg (US)
don't know where your getting your information from but 24's & def 19's are not sufficient for a supercharger. you will be at 100% duty cycle. you would want 30's at a minimum and even at that 36's would be giving you a little room to add more boost. 42's would give you plenty to grow with.
check out an injector chart, just my .02
good luck
Old 12-12-2012, 08:41 AM   #46 (permalink)
24s r fine...it's not like I'm building a beast overhere...it's just a Lil something. 24s have been done with no problem
Old 12-12-2012, 08:52 AM   #47 (permalink)
EcoModding Observer
good luck, subscribing
Old 12-12-2012, 09:30 AM   #48 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
I'd take his advice and go with at least 36s. And larger pump. I had an 89 gt stock block/crank/rods/pistons/heads/ intake. I only had a cam in it with 1 3/4 headers. With only 4 lbs of boost I was at 340 hp at the wheels and I ran out of injector. ( they were 24s) this was dyno tuned on a mustang dyno and it was a paxton centrifugal. Also the tuner said once you hit about 500 horse the fuel lines must be upgraded from the stock( which i think is "5/16) to 3/8.
Should be able to tune it for mileage. Just make sure it's a good tuner who totally understands you want a lean cruise with no boost until you really get into it. Gota be careful especially with a stock bottom end. There was a civic on here that tuned 230 horse to the wheels but was specifically tuned for mileage at cruise. I think he was getting like close to 60mpg.
The Following User Says Thank You to slownugly For This Useful Post:
mcrews (12-12-2012)
Old 12-12-2012, 11:17 AM   #49 (permalink)
With the vortech it's only going to push around 280 with an fmu but I plan on using a tune which should put it around 330ish area and yes I am upgrading the pump to a 255lph...if I happen to need bigger injectors Ill get them but I got the 24s for $40 so I went ahead and installed them...can't go wrong with that.
Old 12-12-2012, 11:33 AM   #50 (permalink)
That's a very good deal!! I think new sets are upwards of 300 bux if I remember correctly
