Old 04-28-2012, 08:23 PM   #271 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
I'm very interested in the gap filling mecanism and i think a new thread on it is needed. I did recently some CFD test with Solidworks and -15% cd reduction when a large gap between trailer and van was filled.
I'm think in someking of selfrolling canvas with the needed degrees of freedom and some magnetic help or a litttle kammback, or hundred of not clear ideas.
http://ecomodder.com/forum/showthrea...tml#post303838
in the attached files you could see
the van shape with cd=0.36
the van with trailer with equivalent cd=0.277
the gap filled one with eq. cd=0.233.
Name:	furgo remolc forat.jpg
ID:	10761   Click image for larger version
ID:	10762   Click image for larger version
Sold:
The Following 2 Users Say Thank You to ausias For This Useful Post:
aerohead (04-30-2012), noxman (03-02-2013)
Old 04-30-2012, 05:54 PM   #272 (permalink)
canvas
Another modder is going to use a tensioned fabric for the diaphram.I'm not at liberty to discuss any details.
I figure,the gap-fillers will end up like the original Mr.Coffee.When this domestic version of Bunn's commercial coffeemaker hit the store shelves,it was no time before a dozen competitors rushed in,ducking and dodging any intellectual property rights held by Joe DiMaggio's patron.
Articulated buses and Walt Disney's Monorail have had good 'solutions' since I was a child.
Old 05-01-2012, 07:15 PM   #273 (permalink)
90 day: 19.36 mpg (US)
There's a limit to my skills (primarily a shed and weighted tons of tools, not just experience; i.e, welding) but as with belly pans I am most grateful for examples. Even a moderate change to the inter-vehicle gap should show help for mpg and handling (the second being at least as cruical as the former), and I am deeply indebted for what I have learned so far.
Old 06-12-2012, 06:05 PM   #274 (permalink)
low sodium diet for Viking
Viking won't be going to Bonneville this year.
I'm being eaten alive with competing activities.
There's no H-rated tires available to 'make it' as a 2-wheeler
Not enough time to convert to 1-wheeler
I'll let the old boat tail rise from the ashes and add some improvements.
Viking is too heavy for the short course.'N no guarantee that USFRA would let me run the long course even if 'traffic' were light.
The tail is light and will provide the best opportunity for the T-100 to reach terminal velocity if at WOT for the entire mile.
All the safety requirements have been met for Bonneville and I'll use the interim time to strengthen,refine,and modify.I got a free ARE fiberglass tonneau cover which will replace the aging,eyeball-detroying,warped plywood aeroshell base.
I do plan to do a run to Monahans with the trailer at 70 mph and see how numbers compare with earlier runs sans trailer.The wheel bearing/speed-temperature issue doesn't appear to be that crucial after the last tests.And I've learned how to keep the wheels on the trailer!
I've got quite a bit of 70 mph data on the truck with which to compare.
After September,if I haven't destroyed the engine at World of Speed,I'll 'look' at the 1-wheel conversion.The truck has 346,000 miles on it now.Some say that these are 1,000,000-mile trucks.Don't know.
BamZipPow (06-12-2012)
Old 06-12-2012, 06:47 PM   #275 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Phil, which event/what dates will you be at the salt flats?
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 06-13-2012, 12:10 AM   #276 (permalink)
last year opening weekend had very short lines in early august. the salt was such everything went very smoothly and tracks were all great.
Old 06-13-2012, 02:22 PM   #277 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
What size SI and LI do you need ?
The Following User Says Thank You to euromodder For This Useful Post:
aerohead (06-13-2012)
Old 06-13-2012, 04:22 PM   #278 (permalink)
which
I'm doing the USFRA World of Speed,September 8-11.I'll be running as an 'experimental' on the 130 Club short course track.
That's if I make it.If not for defensive driving,I'd be in a collision nearly every time I leave home in the truck.Viet Cong were friendlier than many motorists I encounter.
Old 06-13-2012, 04:26 PM   #279 (permalink)
skyking's Avatar
Darn.
I have a camping weekend starting Thursday the 12th. I'd have to book on home the 10th to make that.
2003 TDI Beetle
2002 TDI Beetle
The Following User Says Thank You to skyking For This Useful Post:
Old 06-13-2012, 04:44 PM   #280 (permalink)
need
The real issue for the 2-wheel configuration is the wheel size,8-inch.
While I might 'see' what 80-mph cruising would be like (I've been to 88 mph with Viking during passing),I can't imagine taking the wheel bearings over 100,let alone 120-130.
I can't put larger wheels under Viking due to body/frame interference and major re-engineering.
The 1-wheel conversion is doable except for the time it would require.And I have a new hernia which will require surgery and prevents me from some of the physical type of work necessary to pull the conversion off.
I have the HONDA Hawk mechanicals and Dunlop touring H-rated tire to do it.These would fit under the centerline of Viking with no problem.
The anti-tilt hitch connection would require re-engineering of the gap-filler mechanism which has already consumed over 200-hours.
I just don't think it's realistic to have any expectation of completion.
Doing the boat tail is very realistic and it's low weight would mean a lot with only a 1-mile run-up on the salt.
If I had good numbers for a full boat tail it might wet my appetite for a clean-sheet trailer which does not have the extra length and weight of Viking.
With Viking 'Light' I COULD do the short course with reasonable certainty of achieving terminal velocity.And we'd have some good data for the range-extender trailer concept.
Tractor Trailer Boat tail trikkonceptz Aerodynamics 26 01-07-2025 03:18 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Trailer Hitch Boat Tail? superchow EcoModding Central 16 04-26-2010 02:35 PM
