Old 03-10-2013, 02:44 PM   #11 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Originally Posted by Vekke View Post
Good target but going to be difficult to reach that for summer 2012 .
Flux capacitor
Old 03-10-2013, 02:47 PM   #12 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
D'OH!!!! I always default to the previous year about this time.
Good catch Vekke, I am a bit of an idiot sometimes.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 03-10-2013, 02:52 PM   #13 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Is it NA or is it turbocharged?
It seems that turboing the diesels nets a fair boost to FE.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 03-10-2013, 03:13 PM   #14 (permalink)
Diesel
Just an NA. 54 screaming ponies( when new). I like the engine as is. I know that electronic injection and turbo charging do make for a more efficient engine( being a Freightliner tech.), but this is what I have.
Boat tail project
Old 03-10-2013, 04:27 PM   #15 (permalink)
Have you tried a CAI?
Cold Air and Ram Air - EcoModder
Apparently diesels like air.
Old 03-10-2013, 04:36 PM   #16 (permalink)
I'm in, this summer i hope to do a 75-80mpg tank.
I try to be helpful. I'm not an expert.
The Following User Says Thank You to sheepdog 44 For This Useful Post:
JethroBodine (03-11-2013)
Old 03-10-2013, 05:07 PM   #17 (permalink)
Diesel
I have a replica of the stock fresh air intake from the air cleaner assembly to the right front headlight bezel. This is fed fresh air from the holes in the air dam, ahead of the radiator. Improving it is on my to-do list.
Sheepdog- Ha! 80 it is.
Slight hiccup on this tank, a wire tie holding my fuel return hose broke and the hose fell onto the timing belt, wearing through the hose. I've made a temp fix and will fix it properly tomorrow.
Boat tail project
Old 03-10-2013, 10:01 PM   #18 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Calibrate your speedometer and especially odometer against a nice GPS. Stock setup can underreport miles - mine did. That way you give yourself full credit for actual miles. I'm not saying to adjust it. Just work up a correction multiplier so you can derive the true miles.
Coast long and prosper.
Old 03-11-2013, 09:16 AM   #19 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I am pretty sure that Jethro has a GPS in his car.
Noah Webster, 1787
Old 03-11-2013, 09:24 AM   #20 (permalink)
Do more with less
I have some engine work planned this spring on my VW. Am hoping for 2oz/mile. I am going to steepen the rear foil on it.
Still running my snow tires. They should still be good for this summer.
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
