11-18-2014, 09:21 PM
Good or bad grill block?
I was wondering about my winter grill block and what you all think about it. Is it hurting my areo or helping it. My temps stay normal in the 173-180 deg f area. Unless it gets over 60 outside.
11-18-2014, 09:31 PM
Looks good to me.
regards
mech
11-18-2014, 09:51 PM
I don't know about the sides being open if that created bad turbulence. I was wondering if it would be better to block it all the way across or if it gets too hot, to block off the outer parts and leave a hole for the center.
11-18-2014, 09:59 PM
180f? Do cars actually run that cool? Last two I had run at 200f.
11-18-2014, 10:16 PM
Looks good to me, but try blocking all the way across and watch your temps.
Both of my cars run about 185 F, and the motorcycle about 177 F.
11-19-2014, 12:50 AM
I'm going to try all the way across and see
This is after a 53 mile drive at 65 mphin 17 deg weather. I pulled into the garage and snapped this.
Rock auto shows a 180deg thermastat for the 12 mazda 3 2.0 skyactiv manual.
My wife's jeep runs above 200
11-19-2014, 01:57 AM
Temps look normal to me considering your level of grill blocking, the cold weather, and assuming efficient driving techniques. The fact that you are 8 degrees below the rated temp tells me you can block even more. Try blocking the entire lower grill.
I can get away with about 90% grill blocking on my vehicles during our more moderate winters.
11-19-2014, 02:00 AM
Can't hurt. Block the brake vents too unless you're crazy hard on 'em.
11-19-2014, 02:33 AM
#9 (permalink)
Originally Posted by taco
Off topic, but I'm surprised you're idling at 0.19gph with that Skyactiv engine. My 1ZZ-FE (designed in 1999) is 0.18-0.19gph idle. I would've hoped that with direct injection, high compression ratio, better VVT, and such that they would've been able to cut idle consumption more than 10% (since the displacement is bigger on the Skyactiv).
11-19-2014, 02:56 AM
#10 (permalink)
At 17 degrees outside temp, I'm guessing the seat warmers and heater was on. Perhaps the headlights were also on. This would call for higher idle consumption.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
