Old 03-17-2012, 02:15 AM   #1 (permalink)
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
grill block idea
rather than just blocking off the grill, how about making a grill block that goes in front of the grill, and slopes out toward the bumper ?
Old 03-17-2012, 03:27 AM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
if you would post the car you have it qould help the conversation
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 03-17-2012, 11:06 AM   #3 (permalink)
mikehallbackhoe
I have an 84 crx hf. but I think most cars , in general , would benefit from a sloped grill block. if you just put a grill block on most grills, it is going to be straight up and down, which can't be good for aerodynamics.
Old 03-17-2012, 01:39 PM   #4 (permalink)
Crx
Honda did a pretty good job of grille-blocking on the production CRX.
If your's is non-AC you will already have an internal full-block panel that closes the hole where the condenser would reside.
Some of the grille has 'dummy' sections.
I fabricated a complete fiberglass nose with integral Walter Korff pinched inlet duct.I can't tell you that it showed that strong at the pump.It hardly showed near 100 mph at Bonneville.
I would recommend rocker panel extensions to get the sides even with the tires.
The front wheel wells are bigger than need be.Some of this can be closed off at the top without interference with the tires.
Rear wheel skirts can be cast directly on the car with a proper release in place.
Leave the mirror(s) alone.They are plenty fine as is and Bonneville proven.
The underside needs a cleanup with sections of belly pan and diffuser.
The big savings are at the back with some boat tail.One foot of length will get you into 60 mpg territory at 55 mph with the other cleanups.
Old 03-17-2012, 03:21 PM   #5 (permalink)
mikehallbackhoe
mine has a.c. but it doesn't work, and I planned on removing it anyway.
Old 03-17-2012, 03:44 PM   #6 (permalink)
AC
Only one of my California cars had AC and I never used it.The climate was so good there was rarely any call for it.
If you ever head this way in summer though,you'll wish you had it.
Old 03-17-2012, 03:55 PM   #7 (permalink)
The Truck - '02 Nissan GU Patrol ST
I made mine a bit pointed at front bottom, so at bumper it is inverted "V" shaped, and then tapers back at sides to meat headlights, and tapers up to merge with bonnet/hood curve, don't know if it is better or not, the main reason I did it was to try get a more gentle curve where grille block meets bonnet, so minimise risk of seperation.
Old 03-17-2012, 04:04 PM   #8 (permalink)
"Meat headlights"... can I post this? Pretty please???
Re: front: doesn't seem to matter much if the leading face is vertical or slanted, as long as it blends nicely with top and sides.
Old 03-17-2012, 05:51 PM   #9 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
This is basically what I have done on my car. Made a sloped form that sticks out in front of the OEM grill and bumper and which contains a driver adjustable grill block with an grill inlet below the stagnation point of the grill block/nosepiece.
aerocivic.com
Old 03-17-2012, 06:08 PM   #10 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Bacon makes everything better...
