Old 10-25-2012, 06:51 AM   #1 (permalink)
Passat - '06 VW Passat SE
Grill block mounting help
Im looking to make a set of brill Blocks for my VW Passat and im making them out of clear Perspex so they are as clean and stealthy as i can get it as i want to have a factory fitted look but my problem is how can i mount them with out having bolts or cable ties showing?
im looking to do all 3 Lower grills with a vent in the center grill.
Also a Half block on the Large center Grill with the VW Logo.
I want it to look a clean as possible.
Thanks
Carl
Old 10-25-2012, 07:47 AM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Maybe you could cut grill block with some additional mounting points, heat them up and bend to the inside, then use zip ties or screws to mount it?
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following 2 Users Say Thank You to AndrzejM For This Useful Post:
aerohead (10-27-2012), c4a8l (10-27-2012)
Old 10-25-2012, 08:45 AM   #3 (permalink)
I did think about that but there isnt enought clearance between the bumper and the grill.
Old 10-25-2012, 08:55 AM   #4 (permalink)
AndrzejM's Avatar
Can you take a pic of the actual front of your car? That will be easier to see what we're talking about.
Old 10-25-2012, 09:24 AM   #5 (permalink)
Yes i will get one up in a bit.
Old 10-25-2012, 09:26 AM   #6 (permalink)
The grills are a tight fit in the resess of the bumper the upper grill should not be a problem its just the lowwer grills.
Old 10-25-2012, 09:31 AM   #7 (permalink)
AndrzejM's Avatar
Why you don't want to use those holes in a "black" area? The actual grill...
Old 10-25-2012, 09:35 AM   #8 (permalink)
The two side grills are only half open and dont fancy having visable cuts in them.
Old 10-25-2012, 09:55 AM   #9 (permalink)
AndrzejM's Avatar
Maybe some thin pieces of inox, screwed to the Prespex and fitted into the tight space between grill and bumper cover?
The Following User Says Thank You to AndrzejM For This Useful Post:
c4a8l (10-27-2012)
Old 10-25-2012, 10:53 AM   #10 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
You could put the grille block on the inside, for that stealthy look.
