Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 03-04-2014, 05:33 PM   #91 (permalink)
IamIan's Avatar
Originally Posted by maxc View Post
The University of Arizona did the tests. So your saying there're clueless!
No, I am not claiming that.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
Old 03-04-2014, 05:44 PM   #92 (permalink)
IamIan's Avatar
Originally Posted by RustyLugNut View Post
There are numerous books and papers that discuss combustion dynamics, but the basics follow the outline to increase flame speed and the heat/pressure release to drive the piston.
Note:
Increases in Flame speed does not necessarily increase power or efficiency.
For example:
The Lean Burn operation in Gen-1 Insight is actually a slower flame speed , but yields a higher energy efficiency... where the rich burn in the same engine has a faster flame speed , but a lower energy efficiency.
I will briefly discuss the first four points as a group and then the last point in a more extensive fashion as that relates to the original post. As both Niky and Tvago have pointed out, water injection and EGR change the chemical reactivity rates and surprisingly to some, they can be used to accelerate and stabilize certain flame situations when all logic tells us they would quench the flame.
Bold
Incorrect.
Old 03-05-2014, 01:19 AM   #93 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
But unless you are pgfpro, the shear audacity of the undertaking leaves most people to attack the low hanging fruits of Ecomodding - aerodynamics, weight and rolling resistance. By definition, all Ecomodder's are crazy, but pgfpro and others are reaching for the mountain peak, the last few percent.
There are numerous books and papers that discuss combustion dynamics, but the basics follow the outline to increase flame speed and the heat/pressure release to drive the piston. Flame speed is increased by:
added fuel. Increasing mixture richness or lower AFR.
added pressure. Flame velocity is lower at partial throttle, higher at full and boosted levels - all else being equal.
added turbulence. Flame velocity is increased with added port tumble, squish and piston dome shaping.
added heat. Especially at the spark ignition point, a hotter fuel mix contributes to flame speed.
added chemical reactivity. Racers have used various compounds over the years to not just fuel, but change the engines power profile. Nitro-methane and hydrogen peroxide are just two that have been used.
All five categories I have played with
#1)
My most hated part of my lean burn engine. The leaner you go the more ignition advance you will have to run due to a slower lean A/F flame speed.
More ignition advance lowers efficiency due to the piston fighting high cylinder pressure before TDC.
This becomes even more of a problem when running a lean burn engine during light load conditions. At light load you are making very low power, and the effects are much much greater on power out-put by percent.
Back to my first problem... running to much ignition advance knowing the engines efficiency is suffering from it? So I add fuel to increase flame speed. Add fuel power goes up, "what... I don't need any more power", that's why I did all those aero mods to run less power at light load??? So I'll fix that by less throttle pedal. But now I increased engine vacuum so I just increased pumping losses. Crap!!!! Plus decreased flame speed due to partial throttle, so my ignition advance needs to go back up.
#2) is my solution, "turbo charge my N/A engine". Lean burn engines want more ignition advance and thus decrease engine efficiency, but I can offset some of that by utilizing number two. At light load I can run at zero vacuum or at freeway speeds and a positive boost of around 2 psi. Pumping loses are improve drastically and flame speed is back where it needs to be so I can run less ignition.
#3) I need to add turbulence. This is part of my intake port runner design to feed air and fuel to the top of the port across the exhaust valves and tumble downward over the top of the piston and back toward the intake valves.
#4) Add heat to increase flame speed. At light load my turbo compound system runs with no inter-cooler. IAT temps are 200*F or more. Lean burn helps also with this due to a lower fuel endothermic reaction.
#5) now hang because this is where it gets a little strange. Last year I did testing at light load lean burn using Nitrous-Oxide to increase flame speed. It work awesome!!! I was running as little as 5* BTDC advance with no miss fire and no eternal damage. Keep in mind the amount of N2O was equal to a N2O solenoid leak. Around 2.52 lbs/hr of N2O. Not cost effective ($3.25 a lb. my cost) but interesting to say the least. lol
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
IamIan (03-05-2014), sheepdog 44 (03-05-2014)
Old 03-05-2014, 01:45 AM   #94 (permalink)
You jumped on stage before I gave you the cue!
#1)
I know you have done much work in the topics discussed and I was going to ask for a follow up post from you. But your post is still welcome at this stage and we will refer to it as we move on and expand on it. I especially like the graph pictured. Is there any way to re-post it with more clarity.
Old 03-05-2014, 01:57 AM   #95 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Try the new picture it looks better.lol
Really good read on lean burn H2 CO
http://dspace.mit.edu/bitstream/hand...1/54629063.pdf
IamIan (03-05-2014), niky (03-05-2014)
Old 03-05-2014, 08:59 AM   #96 (permalink)
Since they're talking about H2 and CO, then that's based on reformation of fuel instead of a water system, right?
20 ON (RON or MON) is an amazing boost. That's similar to water/meth inejction, without the need for an extra tank/fuel source.
Old 03-05-2014, 12:28 PM   #97 (permalink)
...beats walking...
The 'Conclusions' summary on pages 87-88 make good reading.
The Following User Says Thank You to gone-ot For This Useful Post:
IamIan (03-05-2014)
Old 03-05-2014, 07:31 PM   #98 (permalink)
IamIan's Avatar
yup.
"These mixtures simulate 15% and 30% of the engine's gasoline being reformed in a plasmatron fuel reformer."
and
"The hydrogen-enhanced engine concept uses H2 and CO produced with an onboard fuel reformer"
and
"A fraction of the fuel flow is diverted to the plasmatron."
etc....
Old 03-05-2014, 08:00 PM   #99 (permalink)
Your posts on leanburn are very enlightening and valuable. Answered a lot of mysteries for me.
I try to be helpful. I'm not an expert.
The Following User Says Thank You to sheepdog 44 For This Useful Post:
pgfpro (03-05-2014)
Old 03-05-2014, 08:50 PM   #100 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Originally Posted by IamIan View Post
yup.
and
and
etc....
Yes. It looks like your question was answered.
browns, hho, hydrogen, water
