02-07-2023, 04:12 PM
Is having a hole in my head better than having a screw loose?
I lost bone around the implant and my old dentist is removing it. She said she will give me a quote for a bridge, but I don't know how that would work out since the back tooth has an implant (in my trunk).
Remembering is hard!
I thought it would be weird if someone from the dealership opened a box with broken teeth, but it would have been nice if this dentist could recement them.
How do I Heli-coil my own jaw?!
02-07-2023, 07:10 PM
Diesel driver
"How do I Heli-coil my own jaw?!"
..you start with a good slug of whisky!!
Years ago, I had a large amount of bone removed; some surgically, some by the absess growing there.
It took a LONG time to completely heal.
Good luck!
02-07-2023, 07:43 PM
So you're saying there's a chance!
I do not like the idea of missing bone!
02-07-2023, 08:47 PM
Diesel driver
You're only young?
Good diet, no cigarettes, easy on the booze...you can recover from most things.
02-07-2023, 09:40 PM
I try to take care of my cars, too, and that is a losing battle, but they don't heal.
02-07-2023, 10:00 PM
Fewer teeth means fewer dental problems.
My Metro has taken to not sweeping the wipers as far and then slapping them on the hood.
.Three conspiracy theorists walk into a bar --You can't say that is a coincidence.
02-08-2023, 11:20 AM
loosen whatever device holds the arms on, remove arm , reposition, reinstall locking device. Generally they should be about an inch from the bottom of the window.
02-08-2023, 02:27 PM
Thanks. I suspect some cable mechanism because they are in synch, but that's within the scoop of my capability.
I'm still starting it with a screwdriver. The replacement steering column just sits there and doesn't install itself. I think Xist is being a bad influence on me.
02-09-2023, 01:59 AM
#9 (permalink)
AKA - Jason
My wife is a biomedical engineer and used to design dental implants. What you have is called peri-implantits. https://en.wikipedia.org/wiki/Peri-implantitis
You "heli-coil" your jaw with a bone graph. You keep from losing another implant with excellent oral hygiene that includes daily flossing. Bone loss is caused by bacteria between the gum and tooth / implant generally from excess plague buildup.
(And this reminds me that I need to step up my flossing - as my wife and dentist continue to remind me on a regular basis)
02-09-2023, 02:14 AM
#10 (permalink)
I've wanted dentures from the moment I knew they existed... also wanted a powered wheelchair from the moment I knew they existed.
