Old 02-12-2009, 09:50 AM   #31 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Originally Posted by Nevyn View Post
Use a flexible cutting board from the kitchen dept. They're like 1 or 2 mm plastic. Use tape or something to mark off the segments, then spray it black. It'll diffuse nicely, and be opaque everywhere else - as well as cutting brightness down a little.
That sounds like a pretty good plan.
Old 02-12-2009, 09:54 AM   #32 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Walmart.com: Progressive Color-Coded Chopping Mats, Set of 6: Kitchen & Dining
Little pricey in my opinion. I think the dollar store here where I live has generic "white" ones.
Old 02-12-2009, 09:59 AM   #33 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
I came up with a dirt cheap option that has yielded some pretty good results.
I took my number template (attached) and secured a strip of clear packing tape (sticky side up) on top of it. Then I cut small strips of aluminum foil and progressively covered sections of the pattern. After I was done I covered the foil side of the assembly with another strip of clear packing tape.
I really wish I had a camera here because this came out really well with really crisp edges . I'll try to get pics up asap.
Old 02-12-2009, 10:43 AM   #34 (permalink)
I have a spare sheet of Plexiglas that I'm gonna sand down for a diffusing layer.
Old 02-16-2009, 04:26 PM   #35 (permalink)
deleted
[bizarrely off-topic post removed by admin]
Old 02-16-2009, 04:27 PM   #36 (permalink)
...huh?
Old 05-01-2009, 04:45 AM   #37 (permalink)
Eddles's Avatar
Eddles's Astra - '01 Vauxhall Astra ECO4
90 day: 61.03 mpg (US)
I know this is not what you all are looking to do, just giving you all a heads-up. I've got this HG100 GPS HUD in my car so I can keep a close eye at the speed at *all* times without needing to glance at the speedometer all the time. This works quite well even in the daytime, and I didn't bother using the supplied tint. This helps me to keep my speed constant, thus increasing MPG slightly. This is bright enough that they had to put in a light sensor to dim the display when dark. I brought this for about $60. This also has a bluetooth link so I can use this with other things such as mobile phones etc, and the display can be turned off. Well useful gadget, and I'm very impressed with it. Chinese designed and built, but very good quality, better than most stuff I've seen (Euro made, US made, whatever). Even the packing was the best I've seen, I felt quite guilty to put it in the recycling bin, wanted to put it on a display shelf! This originally cost $150 which *is* far too excessive, but $60 is a lot more reasonable.
Unfortunately, this doesn't have MPG info, which is what we all want, eh!
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
Old 05-05-2009, 09:43 AM   #38 (permalink)
Ex-lurker
Well, technically it works on the same principal with the hard edged diffused LED display. If you find a busted one and hook up to the Guino's serial output, you're all set :-)
Old 07-02-2009, 07:42 PM   #39 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Instead of trying to add layers/distortion to reduce brightness, has anyone tried using a potentiometer as a dimmer switch ?
Reduce V IN and output will drop accordingly. I used to make LED annunciator panels. To get the clients attention where it was more critical we used different values of resistors. The rule is you can overdrive the LED until it gets warm safely. Run the voltage up until it gets hot(very briefly), back down until its only warm, then measure the ohms of the pot. Place a fixed value resistor of that value inline with the pot and it will prevent the hand on the pot from blowing anything.
Keep us posted !!!!
Old 01-18-2010, 08:00 AM   #40 (permalink)
Any word on the finished product and photos?
Screw heads? Sean T. Aerodynamics 3 09-24-2008 10:21 PM
Can you change the scanguage display "rate" default to FAST? blackjackel Instrumentation 8 08-27-2008 02:09 PM
Analogue MPG display using an OLED? ecoxantia Instrumentation 2 08-22-2008 08:23 AM
2x16 LCD Display issues/discussion dcb OpenGauge / MPGuino FE computer 29 08-19-2008 07:25 PM
E.O.C. cracking heads? scissorhands EcoModding Central 8 07-12-2008 10:16 PM
