Old 06-13-2010, 05:16 PM   #21 (permalink)
debbott
Fuel Economy
I am on an island in the Florida Keys. Therefore, short trips reduce mpg. I am currently getting 22 mpg with a 1991 gmc sonoma pickup. When you consider huge, heavy canvas, that isn't bad. Most of my trips are under 5 miles from the shop. You are right. Every detail matters and will affect youhttp://dotable.com/images/smilies/turtle.gifr mileage.Debbott
Old 06-29-2010, 09:37 AM   #22 (permalink)
jusnicho's Avatar
Midg - '99 Hyundai Accent HTCBK
90 day: 37.33 mpg (US)
Landy - '02 Land Rover Discovery II SD
Last 3: 17.44 mpg (US)
Pilot - '05 Honda Pilot EX
90 day: 21.22 mpg (US)
MZDA - '10 Mazda 3 iTouring
90 day: 37.8 mpg (US)
F150-project - '04 ford f150 xl
Been doing this for a while.
17-18 mpg Discovery
34-37 mpg hyundai accent
JusNicho
"Drive it like you're
running outta fuel."
Old 11-24-2013, 09:56 AM   #23 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Problems with my method?
This has been my method for years:
1)Fillup on the fast pump setting, clicks off
2)put on lowest setting, clicks off
3) repeat #2
4)fill until fuel visible
-Stop at anytime if fuel gushes out.
Then follow the typical miles/gal. This has worked well for me over the years over the tankful (56-64). My mgpuino is going in over the Christmas holidays that should validate my data.
Problem:
Recently, I have been using shorter trips 180-250 to separate the town and highway portions of my tank. This gave expected results in town (44.8 mpg over 230 miles) due to the car lines (like a drive thru for picking kids up at school) and high speed (75-80 mph) highway (61.5 mpg over 180 miles). Problem is my normal slow speed highway version (50-65 mph, over 180 miles), is giving me numbers that seem far too optimistic (90.4 mpg). Is there something wrong with my fill-up process?
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 11-24-2013, 12:32 PM   #24 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.3 mpg (US)
There are settings on the fuel pump?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 11-24-2013, 03:25 PM   #25 (permalink)
Lots of Questions
Oh! These are the pumps that have the three little bumps so you can go slow, medium and fast, right?
I don't think these are allowed in CA anymore, which is why I was confused about you're talking about. We have two speeds: off and on!
Best EM Quotes:
Old 11-24-2013, 05:32 PM   #26 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
What? Really? Any idea why that might be?
Old 11-24-2013, 10:15 PM   #27 (permalink)
NightKnight
Subaru
Diesel
Huh. When I filled my gasoline car about two weeks ago, the stops were still on the nozzle. I always take advantage of that because I like to check the oil while the fuel is pumping. Must be very recent, though I can't find anything in the news. I'll have to see what I can learn about it.
Sorry, off topic...
Old 11-25-2013, 12:58 AM   #28 (permalink)
Lots of Questions
The "cruise control" is not what's been banned. The pumps used to have notches on the bottom part of the handle. For whatever reason, I can't find any articles about it though.
I do the same thing: let it pump itself, and then check my oil (and clean my windshield for good measure).
Best EM Quotes:
Old 11-25-2013, 06:43 PM   #29 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
In Europe, we only have 1 setting where we can lock the pump lever these days.
If you can lock it at all, as the locking feature is often removed from pumps, so you have to squeeze it during filling.
You can manually squeeze the lever a little bit and get a slower fuel flow though.
Don't the Canadian pumps allow for that ?
Old 11-25-2013, 06:47 PM   #30 (permalink)
A gas cap in the handle works well as a lock if the lock has been removed. I've only had to do this a couple of times in my trucks (40 & 120 gallon tank) when the lock was broken. otherwise I'm not there long enough to worry about it.
