06-18-2017, 08:49 AM
#31 (permalink)
Originally Posted by JRMichler
The original solution was a vacuum actuated clutch. Take foot off gas, clutch disengages. Step on gas, clutch engages. One foot operation.
But the need for a vacuum provision made it unsuitable to certain engines, mostly Diesels and some newer gassers that are resorting to direct injection and getting rid of the throttle plate, and the electronic controls fitted to those vacuum-actuated clutches is still quite complex and not so easy to work on the field. Anyway, when I mentioned cars with manual transmissions adapted for disabled drivers, I was actually refering to full-mechanical devices, such as this hand clutch lever fitted to a split-window Kombi by its owner who had the left leg amputated.
Then automatic transmissions came along and became the preferred solution in the US. That did require shifting the gas pedal over to the left side for those who lost their right leg. I got my driver's license with a left foot accelerator.
There are some right leg amputees in my country who are using hand controls for brake and accelerator, since it's cheaper than a vacuum-operated clutch control and much easier to install. Even some truckers are resorting to this.
My dad knew an amputee that drove a motorcycle.
Whenever I saw anybody with a disability riding a motorcycle, it had been converted into a tricycle. The only exception to that is my dad, who has a left leg disability but still can drive vehicles without adaptations, even though now that he's getting older he's starting to consider getting an automatic for his next car.
06-18-2017, 04:26 PM
#32 (permalink)
Just cruisin’ along
That's pretty similar to the old Borg-Warner overdrive boxes, no?
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
06-19-2017, 03:38 AM
#33 (permalink)
I'd actually rather relate those auxiliary overdrive units to the dual-range feature of the transfer cases in 4WD vehicles, even though shifting between the ranges on a transfer case usually requires the vehicle to come to a stop (even when they're able to shift between 2WD and 4WD on-the-fly).
06-19-2017, 08:41 AM
#34 (permalink)
Rat Racer
Something tells me that the US automotive industry wasn't thinking helping amputees drive. It wasn't 'till the 1990s that we passed a law requiring wheelchair ramps and the like, and people still fight that "overregulation".
The carcos were just thinking about selling to idiots.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
06-20-2017, 01:58 PM
#35 (permalink)
Sure the accessibility issue was not a priority for the auto industry in the '40s and '50s, but at least Oldsmobile had advertised that automatics were easier for wounded WW2 veterans and the polio victims to get them fitted with hand controls, since it didn't require any clutch control.
06-20-2017, 02:10 PM
#36 (permalink)
...beats walking...
I vaguely recall that GM-Olds advertising.
06-21-2017, 04:48 AM
#37 (permalink)
Oldsmobile offered it as the "Valiant" hand controls. The vehicles fitted with them could get even vacuum-booster for the brakes before it became mainstream.
https://www.hemmings.com/magazine/hc...6/3739371.html
08-02-2017, 04:28 PM
#38 (permalink)
halos.com
Originally Posted by 14'ecocruze
The worse mpg is coming from them designing them to get worse. It's in the gear ratios. Try to tell me an automatic is more efficient when a computer is in charge is a lie. Idc if you have a 9 speed auto or whatever they are coming out with now vs a 6 speed manual or even a 5 speed doesn't matter to me. I will get better milage than the automatic as long as the final drive is the same. If a car is marketed as a manual having lower milage highway than a automatic they have different final drive.
Just woke up so hope that doesn't sound mentally challenged
I think there is some truth to what you are saying. It was nearly impossible to find a version of my truck in 2007 with a manual. Only 10% of production. Then, the 6-speed's gearing placed 6th at a 0.79. My dogmatic's 4th and 5th are 0.75 and 0.67. I smelled a rat then, and still do.
Today you can't get a half-ton pickup with a stick. Only something with a diesel in a 3/4 ton. Sigh.
Maybe we need to put together tranny swapping businesses...
EDIT. Consumer demand will make the change happen, or it won't. As long as people buy auto trannies, we'll be stuck with that or with our old vehicle, or with a conversion.
08-02-2017, 05:10 PM
#39 (permalink)
Here in the UK most cars are manual. We are now getting a few more automatics with the popularity of CVT (spit) and DSG (broke again has it?). Luxury cars, after years of offering automatics as an option, are now only automatics (Jaguar XJ, BMW 5 series), though the XE and XF offer manual as does the BMW 3 series.
After 25 years of driving manuals I bought an automatic (very cheap and knew its history (family member selling it). That was me hooked. I then drove automatics for the next 26 years then bought another manual. Much prefer an automatic in modern traffic conditions, especially city driving.
Here in the UK, if you pass your test in an automatic you are only allowed to drive an automatic. If you pass your test in a manual you can drive either.
I sat my PCV licence (Passenger Carrying Vehicle) so I could drive coaches. It was for automatics, a Class B licence, meaning I could only drive coaches with an automatic transmission, but that was all my company used in our area,
08-02-2017, 06:06 PM
#40 (permalink)
Don't you need to distinguish what type of auto transmission you are talking about?
The Honda NC/CTX700 motorcycles offer an option of the Dual Clutch Transmission, which on my 2nd gen bike has an econo "Drive" mode, a "Sport" mode and a Manual mode, or you can perform a manual up/downshift while in the automatic modes. The transmission is a standard 6 speed, not a CVT or a torque converter, only the clutching/shifting is controlled, so I don't see how it could give any less mileage than the same gear box being shifted with a foot lever and a hand clutch lever.
cheers,
Michael
