08-21-2014, 02:03 AM
How To Hypermile in neighborhoods?
Hey everyone!
I drive mostly on the highway but occasionally I have to drive through neighborhoods to run errands or visit family.
They have speed limits about 20-30 MPH and many speed bumps and stop signs every 500 feet. It causes me to slow down and BRAKE (ugh). There's no other route I can take...believe me, I wish there was.
My area has many rolling elevations as well.
Can anyone offer any advice as how to get he best mileage in these situations??
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
The Following User Says Thank You to SilverCrown9701 For This Useful Post:
08-21-2014, 06:55 AM
Cyborg ECU
Sometimes you just have a crappy stretch of your route, but generally there is a way to make it an advantage in some way. In this situation you are EXPECTED to gow slowly. That can be a hypermiler's dream. I have an area that reminds me of what you describe a little. I climb a steep hill from a stop, cross three speed bumps, and end with a downhill that I can't use for a free coast because of a left hand turn I have to make at a tough to see light at the bottom of the hill that is nearly always red. I go slowly. Sometimes i cross the speedbumps at there edges so I can get away with a couple extra mph. I park on that final hill, at a safe spot where I can see the light. When it's about to go green, I coast down, bump start, make my left. This is actually the better of two choices I have in my route at this stage.
08-21-2014, 07:08 AM
What brake pedal?
If the speed bumps are properly engineered, you should be able to maintain the posted speed limit w/o the need for constant braking. Unfortunately this doesn't always hold true, so YMMV. Can't really pulse & glide with those nasty speed bumps around
Most drivers around here race up to speed bumps & then over brake to compensate. (this is when the skilled hypermiler catches back up with them & gets pissed cause it screws up their better thought out strategy) I still don't understand the mentality of most drivers who just drive soley with emotion & zero common sense.
08-21-2014, 08:47 AM
Rat Racer
Accelerate just enough to glide to your next obstacle. That's great stuff.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
08-21-2014, 09:32 AM
Pulse and N coast, 20 mph N coast is 66 mpg with my Cobalt, 30 = 100 mpg. Your probably about the same.
08-21-2014, 11:34 AM
Don't stop at the stop signs?  J/k.
08-21-2014, 01:24 PM
My commute to work has two stop signs 360 feet apart. From the first stop sign, I accelerate to 15 MPH, then EOC to the next stop sign. The important thing is the trip mileage. I average about 35 MPG on the ScanGauge for my three mile (each way) commute to work.
08-21-2014, 01:39 PM
Rat Racer
But officer, I swear I was at zero rpm at the stop line!
The Following User Says Thank You to Fat Charlie For This Useful Post:
08-21-2014, 02:16 PM
#9 (permalink)
This neighborhood has rolling "hills" through the entire area.
There are 2 stop lights at each end of it so there's no getting around that. It also has 4 stop signs and 6 speed bumps.
THEN there's a gated community within that neighborhood that I have to drive into to get to my destination. There are 3 speed bumps and 3 stop signs with a speed limit of 20 MPH but this community is relatively flat.
08-21-2014, 02:17 PM
#10 (permalink)
That's a bit fast over speed bumps. I don't want to trash my suspension and undercarriage.
