Old 03-16-2013, 02:53 PM   #1 (permalink)
blowncopcar's Avatar
Gumby - '97 Geo Metro
90 day: 58.53 mpg (US)
How many degrees is too many? (WAI temperature)
I have a hot air intake installed on my 97 geo metro 1.0 liter... My UG says my temp is going to about 176+ degrees... Is this too much or is it fine? It seems to run okay
1997 Geo Metro 1.0L 5speed
Pass mirror deleted
Custom molded front bumper with top grill closed and 50%summer-90%winter bottom grill closed+ lowered lip BUMPER IN PICTURE IS NOT BUMPER NOW
Partial kamback (in progress)
Headlight covers molded into bumper
Rear underbody tray (suspension to bumper)
Windows tinted 35% NOT PICTURED
Old 03-17-2013, 09:32 AM   #2 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
My saturn runs OK too at that temps. I think it cools down by the time it gets to the throttle body and intake manifold, as the sensor is in the air box. At times it showed over 230F after long driving, hotter than the engine temp, but since have cooled it down to 150 to 180.
- Tony
Old 03-17-2013, 09:01 PM   #3 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
the 1.0 metros being TBI will certainly benefit from warmer air to help vaporize the fuel.
The Following User Says Thank You to RobertISaar For This Useful Post:
blowncopcar (03-18-2013)
Old 03-17-2013, 11:05 PM   #4 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
no one but you can answer this question
measure the answer
i assume you are recording your fuel consumption values
did your FE improve when you tampered with your system ?
yes or no ?
did your calculated load value as measured with UG go down at the same driving conditions
same speed same load same ambient temperature ?
yes or no ?
the ECM will adjust ign timing based on IAT value (among other things) and you may not actually be getting an improvement
or
you may
only you can answer this
so ? what is the answer ?
Old 03-18-2013, 12:37 PM   #5 (permalink)
I am getting better mileage with the hotter temps.... At least opposed to 40 degrees when I first start... I'm not sure about the load %... So yeA i know it's working but I just want to make sure I'm not doing any damage that I don't know about.... Thanks for the replies
Pass mirror deleted
Old 03-18-2013, 09:39 PM   #6 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Is that your steady-state temperature? How did you manage to get your air temp that high?
Old 03-18-2013, 11:34 PM   #7 (permalink)
Yea it's stay steady there on the interstate after about 10 minutes.... I have a tube that attaches to the exhaust manifold in place of the stock intake tube that runs to the filter... I installed it when it started getting cold and my mpg dropped so much, but I'm sure I will have to move it away some during the summer.... Also, I have the top grill opening blocked completely and the bottom blocked 85% or so....
Pass mirror deleted
Old 05-09-2013, 09:17 AM   #8 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Since getting the torque app and now its finally warm outside I've been able to measure intake temps. At about 70 ambient I see around 150f. As soon as I let up on the throttle it drops sharply to say 120, egr is pushing it to 150. Would there be a benefit to blocking the egr and doing more wai/hai? To increase the throttle angle and decrease pumping losses. Btw my engine runs 2100 rpm at 60.
Old 05-09-2013, 09:46 AM   #9 (permalink)
MPGuino Supporter
t vago's Avatar
I'd leave EGR alone. Pumping losses would be decreased, anyway, with EGR in place.
Old 05-09-2013, 10:26 AM   #10 (permalink)
Calibration Engineer
Subie - '00 Subaru Impreza STi JDM
90 day: 22.49 mpg (US)
The challenge is to use the hot air only during cruise. Typically the PCM will pull a proportional amount of extra timing to the load you apply. If you're going to be doing pollute and glide then the IATs can reduce the effectiveness of your acceleration phase.
Of course this makes sense as your cylinder filling and thus cylinder pressures will increase. Old cars are not very sophisticated because emissions laws didn't require emissions results outside a very standard operating range. While hot air injection may save a little fuel the NOX emissions will probably go through the roof. You may be better off working with EGR.
-Michael
