09-19-2009, 03:01 AM
In Lean Burn Mode
How many Ecomodder's are running management?
I was wondering how many of us are using some type of aftermarket engine management?
I'm running Neptune on my Del Sol and Crome Pro on my son's Civic. Both of these cars are turbo-charged. But it got me thinking what the gains you could get from a N/A engine with management?
So is there anyone on here using a after market management system on a N/A engine? If so what improvements have you seen?
Pressure Gradient Force
The Positive Side of the Number Line
09-19-2009, 11:05 AM
Dartmouth 2010
I used to run Chrome, but no longer. I will probably have MIMA in the future, if that counts
09-19-2009, 01:05 PM
I currently use eCtune with my turbo civic. A few years ago cromepro nearly turned me insane.
I'll have to buy more hardware for the new NA project though - won't be too long. The initial costs of tuning are tremendous
09-19-2009, 01:15 PM
In Lean Burn Mode
Yea cromepro has some glitches .lol
09-19-2009, 01:16 PM
In Lean Burn Mode
What kind of gains did you see from your tuning verses stock Honda maps?
09-19-2009, 01:36 PM
Dartmouth 2010
No idea, I didn't have any fuel consumption metering at that point, so I didn't pay any attention, I was primarily using it to turn off codes and run a different basemap, but I went to the z1 about a month afterwards so I never had time to sit down and mess around
09-19-2009, 04:27 PM
eco....something or other
I'm not using management, but if it would help enough, i would try it...
I figure if i can do this well with a heavy car and only half the mods and no Scangauge, i am in good shoes and should be able to hit 50 if i go high dollar.(just don't have the money, i spend it on gas, HAHAHA even at almost 40 mpg...)
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
09-19-2009, 05:43 PM
#9 (permalink)
Pokémoderator
pgfpro -
If I knew then (early 2006) what I know now, I think I would have invested in an Apex EFI.
CarloSW2
09-19-2009, 06:22 PM
#10 (permalink)
In Lean Burn Mode
Thanks for all the replys.
I find it interesting that one can improve on FE and performance over the factory and still pass emissions.
I have tuned over 10+ cars that have reported fuel mileage is now better then stock. Also 8 of the 10 of these vehicles are now FI.
I think that at the OEM level they can't get to aggressive with there timing tables. Plus they don't have individual timing and and fuel trims etc.
