Old 09-19-2009, 08:34 PM   #11 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
If there were an OBD-II compatible programmable ECU, I would have considered it for the Subaru. For my lean burn Honda with catalytic converter management, I'm not going to replace the factory ECU. I might tell it lies, but I won't replace it.
Old 09-20-2009, 06:00 PM   #12 (permalink)
Driving the TurboWeasel
Does having a tuned factory computer count? I have a canned tune running in my car at the moment. I may get a 3800 tuner to clean up the canned tune if I have the funds.
2012 Chevrolet Cruze Eco 6MT
Old 09-20-2009, 08:51 PM   #13 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Yeck yeah!!!
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-21-2009, 02:16 PM   #14 (permalink)
ncs
RockMagnet - '04 Subaru Impreza wagon WRX
90 day: 26.16 mpg (US)
My Subaru is heavily modified and running a tuned factory ecu
RomRaider - Open Source ECU Tools | RomRaider / Rom Raider
I honestly didn't notice any difference in mileage. Fueling is set at stoich and stays there for non-performance driving. As for timing, at lower rpms where hypermiling takes place, my factory settings were already pulling a few degrees of timing from knock detection so there were no gains to be made unless even higher octane(currently at 93) is used.
On modern naturally aspirated engines there also isn't much to do to increase fuel mileage. Most of them are already running at max timing with low octane at stoich fuel, so upping the timing or fuel octane would only result in losses.
I suppose, if the engine was drive by wire, you could limit the throttle to 50% max, or set the rev limiter to 3,000rpm. One area that hasn't been explored much is cam timing. Many newer engines have computer controlled variable cam timing.
Most off the shelf tunes are very conservative to compensate for the differences in engines. My engine doesn't like much timing, but I've seen others with the same motor and similar mods run 5 degrees more with no problems.
Tuning equipment drives the cost of really quick. You need a wideband o2 sesor, and should have an egt gage. Then there's the tuning software. Subaru's is free, but any other make is $$$$. As far as saving money, you'll have to find a once in a lifetime deal to make engine tuning on a modern car pay for itself.
Manyt stand alone fuel computer are MAP based. Most modern factory systems are MAF based. MAF is more accurate for fueling. Moving from an old factor MAP based system to a newer MAF based system would probably see gains. Honda owners might be able to do that.
Emission aren't a problem unless you are missing cats or running a huge cam. In many instances a factory ecu can be kept in place while using an aftermarket ecu to do the real engine management(utec, aem).
Old 09-21-2009, 02:23 PM   #15 (permalink)
Megasquirt on my 190e made a world of difference.
Cost of running an Engine Block Heater Matt Herring General Efficiency Discussion 8 08-14-2009 11:50 PM
Keep A/C from running when you don't need it. TeamCF EcoModding Central 13 04-06-2009 12:55 PM
A Running Log website similar to EcoModder? 1337 Off-Topic Tech 2 03-12-2009 04:28 AM
Any Williamsburg, VA area ecomodders? wydaily Introductions 2 06-13-2008 11:35 AM
