Old 08-18-2008, 08:21 PM   #11 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Originally Posted by BetsyBio View Post
I wondering the same thing about wheel weight as I switch from 14in rims in the winter 20in rims in the summer.
What I have found is that I actually get better mileage with the larger rims, but only when driving mainly highway speeds and P&Ging. Because I can coast farther and take turns at faster speeds without using the brakes I think it also helps the mileage because I can put 55psi in the tires as apposed to 35-40psi with the 14 inch rims.
My question is does anyone think that the inertia of the heavier wheels is the main reason I am seeing an improvement in mpg or is it the higher psi in the tires ?
It's probably a combination of the two, as well as the driving you do. If you did a lot of stop-and-go, you'd see better results from smaller, lighter wheels. Really big alloys are extremely heavy, though ricers will swear up and down that the aluminum 18s they put on their beater Accords make them faster, even though they have twice the weight to turn vs. stock steelies.
Also, winter gasoline formulations will tend to make your FE take a hit, too. You might try running a couple of tanks in the summer with your winter wheels as a control.
If you can properly take advantage of the inertia offered by huge wheels, however, then go for it.
Old 11-20-2008, 05:51 PM   #12 (permalink)
I wondering the same thing about wheel weight as I switch from 14in rims in the winter 20in rims in the summer.............
I think it's probably due to change in gearing with the 20" wheels. I'd imagine they'll be a fair bit bigger than the 14"s in diammeter, so your engine should be doing lower revs for the same road speed. The higher psi may contribute slightly due to the reduced friction.
(sorry for the late reply)
Old 11-20-2008, 05:54 PM   #13 (permalink)
Originally Posted by twolostminds View Post
If I remember correctly, putting light weight tires and wheels on a car will increase your 1/4 & 1/8th mile times
Mike
I think you mean reduce those times. My lighter wheels reduced my times by about 0.15secs
(ooops, think I hit quote instead of edit)
Old 11-21-2008, 08:44 AM   #14 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
why do people think bigger rims = bigger tires? this isn't a sliding scale where 185/60R14 is equal to 265/60R20. The goal is same tire/rim overall dimensions. The 14" overall is 23 inches. To match that on a 20" rim you'd need a seriously small sidewall, like 15. hmm, I could run a 195/20R20. 205/15R20 puts me a hair slower...ah! 235/15R20 is the perfect fit. Now, if only I could make a 235 fit in the wheelwell where a 205 rubs....
thank you for the entertainment, I'm now going to try and find a 20" rim that's 6.5" wide instead of 9-10". should be a challenge worthy of my time.
Old 11-21-2008, 10:50 AM   #15 (permalink)
I know bigger rims don't always mean bigger overall diammeters. On average most people go down 1" or 2" and you go down around 1 profile per inch to maintain a similar overall diammeter. Going up 6" on the wheel alone will be a problem if you're starting with low profile tyres already.
You must have different tyres to what we can get over here as I've never heard of a profile lower than 30 or 25. As far as I knew 15 and 20 profiles didn't exist. So any 20" tyres are going to be bigger than the 14s. If you have incredibly small profile tyres over there, then fair enough. Give me a link as I can't find any.
Maybe BetsyBio can tell us what tyres she has on the 20" wheels to clear up any confusion.
A 185/60R14 works out at 577mm diammeter
A 225/30/20 (smallest I can find) is 643mm and that is going to affect the gearing.
I fitted 215/35/16s to my 16" wheels, they are 556mm diammeter, smaller than quite alot of 14" tyres and 30mm smaller than the tyres that came on my standard 15" wheels and they have helped my acceleration due to being a smaller diammeter.
Old 11-21-2008, 01:46 PM   #16 (permalink)
dichotomous's Avatar
CivySi - '03 honda civic SI
90 day: 31.99 mpg (US)
I went from 32mpg in my civic Si with 195/60r15 winter wheels at 30psi to 29mpg with 215/60r15 tires at 32psi (though going from 30 all the way to 42psi didnt change it much) .
I drive mostly cruising around 50mph but there is about 1/4 to 1/2 city driving, I'd say its a pretty good combined.
I've got a different set of winter tires, same style but 205/60r15 and have them up to 45psi, so we shall see on that, though, its an unfair test because I am also running now a raceheader and I've changed my rear wing to act as an extended decklid instead of a downforce/drag creator
Old 11-21-2008, 04:18 PM   #17 (permalink)
CobraBall's Avatar
Kumho 385/15-22
They exist but how practical, it don't know. Probably ride like solid metal.
Name:	Kumho 385:15-22 .jpg
Old 11-22-2008, 01:38 PM   #18 (permalink)
Originally Posted by CobraBall View Post
Kumho 385/15-22
Well that's a start even though it's a 22" tyre, but I doubt there's anything much narrower like the 195/20s, 205/15s or 235/15/20s made as the almightybmw implied with his sneering attitude, as the sidewalls would be so small that a) they'd be a real pain to fit to the wheels (my tyre fitters struggle with my 215/35s) and b) any hard cornering and the wheel could probably rub on the road due to tyrewall flex.
If you want 6.5x20rims, custom build will be the most likely option.
mind you, when I first started modding cars, the only place you could find 20" wheels was on a lorry. (semi/big rig or whatever they are called in the USA)
Old 11-22-2008, 03:40 PM   #19 (permalink)
Efficiency freak
Bearleener's Avatar
Frugolf - '96 VW Golf wagon
90 day: 40.36 mpg (US)
Tire & wheel weight will definitely have a slight effect and, as some have pointed out, each pound on the wheels counts more than, say, a pound in the trunk (or in the driver's seat). And the more accelerating and braking you do the more it matters. Don't forget also that increasing the unsprung mass leads to additional losses because the tires must absorb stronger hits when going over bumps. Also, if the tires & wheels are heavier because they're fatter, then the aerodynamics will suffer, too. And cheapo steel wheels with stock hubcaps probably have better aerodynamics than most cool-looking alloys.
A little theory:
The linear inertial energy of a car (or its wheels&tires) is
Elinear = (1/2)*m*v^2 ,
where m is the mass and v is the vehicle speed. That means you have to feed in at least that much energy (from the engine) to accelerate the car up to that speed.
Additionally, the rotational energy of a wheel/tire is
E rotational = (1/2)*I*omega^2 ,
where I is the rotational moment of inertia (see List of moments of inertia - Wikipedia, the free encyclopedia) and depends on the mass distribution.
In the worst case all the mass is concentrated at the outer radius (a hoop); in this case I = m*r^2 where r is the radius.
An intermediate case is uniform distribution (a disk, probably a bit optimistic); I = (1/2)*m*r^2.
The ideal best case would be a point mass concentrated at the axle (I = 0), but you can't build a wheel like that (except out of unobtainium).
The rotational speed of the wheel in our case is omega = v/r, so for the hoop we have Erotational = (1/2)*m*v^2 and for the disk it's Erotational = (1/4)*m*v^2.
So comparing to the linear energy you can see that each pound in the wheels & tires indeed counts 1.5 to 2 times.
Some practice: Every year when I switch from summer to winter tires (both 185/60R14 from Continental, same circumference) I notice that the car accelerates a bit differently in 3rd gear. With the summer setup (alloy wheels, weigh 1 kg (2.2 lb) less each; i.e. 15 kg instead of 16 kg for wheel&tire) the car has a surge of acceleration in a certain range of engine speed, whereas with the winter wheels&tires (steel rims) the acceleration is more constant. So even the 6 to 8 kg of equivalent additional mass can be felt on the butt dyno. The perceived difference is more pronounced even than adding a passenger. Go figure!
What I also immediately notice is that my winter tires actually have *less* rolling resistance than the summer ones, even though I'm running the winters at lower pressure. I suspect it's because they're a newer model, where they paid more attention to fuel economy when designing them.
BTW on an earlier thread others found the opposite http://ecomodder.com/forum/showthrea...ires-4838.html , but remember that in the winter other factors (longer warm-up time, less-potent winter gasoline, more air drag at a given speed in colder air) will also take their toll on fuel economy.
You ever notice that birds pulse & glide, too?
Old 11-22-2008, 05:32 PM   #20 (permalink)
Originally Posted by bgd73 View Post
all engines with counter balancers with the 50% "play with itself" design fail with heavier wheels and tires. A 3 main boxer is the only one I have ever encountered that benefits because the engine is true zero'd at all times, all rpms, nothing lost, all gained, and then there is the mythical momentum that extincted it so honda could make a buck with its wiggly little hubcapped crap and folks brainwashed. Uhm. Yeah go for lighter wheels, bad engines need it.For every little wheel wiggling its way in the fast lane today by me bragging about gas mileage I think of all that is fought to death for my country ...how seriously insane am I headed?
wth?
Daschicken (04-19-2018)
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
