Old 05-04-2011, 12:44 PM   #71 (permalink)
#1 is the correct way to do things. If its not starting, the only thing I can think of is that you need to let the cutch out a tiny bit more to spin the engine up a little faster.
Old 05-04-2011, 12:46 PM   #72 (permalink)
Black Beauty - '13 Hyundai Elantra
Ok cool. So then back to my original question: Why is it better to do it that way?
Old 05-04-2011, 12:51 PM   #73 (permalink)
Better than your #2 way of starting? Mostly because its easier and can be done with less distraction from driving. But, by just brushing the clutch against the flywheel, and then rev matching, you have less clutch wear too.
Old 05-04-2011, 12:57 PM   #74 (permalink)
Okay thanks. I will play around with it again and see if I can get it working better. I am keeping it in high gear not going super fast so the rev match point isn't all that far above idle anyway, but I will shoot for optimal.
Old 05-10-2011, 01:29 PM   #75 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Less wear on your ignition system (ie. starter) and your "keyhole" mechanism.
It also uses less gas to bump start because you can fire up the car without the need for the fuel injectors to squirt fuel.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 05-24-2011, 02:34 PM   #76 (permalink)
Good tip! Been using this method to start when my battery is dead for a long time.
Old 03-22-2014, 07:52 AM   #77 (permalink)
Excellent thread. Haven't read all the way through, but, I think I have a post or two somewhere in there.
I have been bump starting for as long as I have been driving, about 35 years. Thought I had it down pretty well but did find improvement in following the initial post of the thread. It had not occurred to me to immediately disengage right after engaging. This definitely does improve smoothness. I even do it if I am at higher speeds and will remain in 5th gear.
I do have something to add though. Most of the posts say start in desired gear + 1 or +2. I simplify this to pretty much always start in 5th at anything more than about 10 mph. This of course, applies to my Sonata, which has a fairly short 5th gear. (I regularly find myself looking for 6th gear) A car with taller gears would mean going to the X+1,2 or 3 formula at a higher speed. In cases where I need to restart at a slow roll, I generally go to 3rd for the restart
bump starting, clutch starting
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
