Old 12-10-2009, 11:26 PM   #11 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Originally Posted by rbrowning View Post
I just cycle between A/C and vent and try to spend as long as possible in the vent setting to reduce the engine load.
My Mustang has a switch to enable/disable the A/C compressor. I use it to "P&G" my A/C.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 12-11-2009, 08:06 AM   #12 (permalink)
In my VX the AC compressor can be engaged or disengaged regardless of the other control positions.
Always use Max and or Recirculate (but always recirculate). This is more efficient because you do not have to remove the humidity continuously in recirculate.
Always cycle the compressor on when you have to engage DFCO, since you are bleeding energy anyway you might as well get "free" AC.
Low fan speeds and compressor manual cycling will keep you fairly cool while minimising compressor actuation.
As Mustang Dave stated, P&G the compressor, on recirculate, with the lowest tolerable fan speed, and you can stay cool with minimum loss of mileage.
I avoid AC use under all but the most extreme circumstances. Actually I try to avoid any accessory loads completely, because they all use fuel to a certain degree.
Some systems cycle the compressor to maintain temp and will cycle less at low fan speeds. Most climate control systems run the compressor constantly and mix hot and cold air to maintain temp. The second type is most wasteful.
regards
Mech
Old 12-13-2009, 01:33 AM   #13 (permalink)
I don't use recirc, because I want fresh air. That means if there is any chance for exhaust fumes from other vehicles or my own tailpipe to get into the cabin, I still have a constant flow of fresh air and positive pressure.
Old 01-20-2010, 08:26 PM   #14 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
i always smell fumes worse when in fresh air mode dont know why.
Old 01-20-2010, 09:25 PM   #15 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I'm surprised you ecomodders haven't discovered this air conditioner controller that shuts down A/C when you're accelerating under load.You can custom-tune this device to max the A/C during glides, and cut it off during pulses, or when hill-climbing.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 01-21-2010, 12:01 AM   #16 (permalink)
I've been doing this for years, because it's so easy to simply press the A/C button to cycle it on or off. If I'm approaching a red light I leave the A/C on, because the car will be slowing, anyway. As soon as the light turns green I kill the A/C until I get back up to cruising speed, at which point I put it back on.
Old 01-22-2010, 09:05 PM   #17 (permalink)
Driving the TurboWeasel
Where I've lived the A/C has been necessary at all times of the year due to excess humidity. It gets pulsed on as needed, and recirculated whenever possible. Sadly the "defrost" setting kicks on both the heater and the A/C. It gets the windshield clean in no time, though...
2012 Chevrolet Cruze Eco 6MT
Old 01-27-2010, 07:06 PM   #18 (permalink)
ecomonkey
what about a resister inline with the fan motor, just pull an old fanspeed unit out of a junkyard and set it to high or med, it should have the result of slowing your fan down to very low (almost off) and this would turn your compresser on and off less often'and blow less air on you for those times when you would normally turn the temp knob .
Old 02-11-2010, 05:48 PM   #19 (permalink)
FastNLoose's Avatar
I unplugged my compressor for the winter so it doesn't run when the defrost is turned on. I really don't see a fuel economy drop people see in the Winter. I'm actully getting better mileage by a small amount and my only change other than the unplug is a grill block.
Old 02-11-2010, 08:20 PM   #20 (permalink)
ecomonkey
good idea fastnloose,,,, i would plug it back in every once in a while to keep all the orings/gaskets/fittings all lubed up ,.
Electric A/c conversion lovemysan EcoModding Central 15 08-28-2010 08:48 AM
Insulating cold a/c lines? CHEGAI EcoModding Central 18 06-30-2010 12:34 PM
A/C Recirc trikkonceptz EcoModding Central 5 07-31-2008 09:49 AM
Better fuel economy with windows cracked, or A/C? dann_04 General Efficiency Discussion 3 07-30-2008 11:26 PM
It's not just the A/C tasdrouille General Efficiency Discussion 4 04-17-2008 11:57 PM
