11-06-2013, 02:48 PM
#21 (permalink)
Typically 0.4 kg/h of low caloric CNG with a warm engine.
With AC on, double that.
11-06-2013, 02:53 PM
#22 (permalink)
Originally Posted by HypermilerAX
I ran the engine for a minute or so in order to expel all the air. I waited for the engine to cool down completely. I noted the value every 10 seconds the first 10 minutes and then 30 seconds until 15 minutes.
I'm really surprised at how quickly the fuel consumption drops off - only the first minute is really the worst.
11-06-2013, 07:15 PM
#23 (permalink)
Master Ecomadman
.2 gal/hr after a 6 mile warm up, sc1 1.9L, gasoline. I try again when it's completely warmed up.
- Tony
11-21-2013, 09:49 PM
#24 (permalink)
Master Ecomadman
.175 gal/hr engine warned up 20 miles, inlet air temp 130F, 700 RPM, I could lower the idle 100 rpm.
- Tony
05-14-2014, 08:11 AM
#25 (permalink)
What brake pedal?
Originally Posted by serialk11r
According to Torque and my Ebay OBDII scanner, 0.18 gph fully warmed up coolant at 680rpm idle for a pre 2003 Toyota 1ZZ-FE (1794cc)
Thanks, I was wondering what the norm was for the 1.8 liter Toyota engine. Scangauge bounces between .16 -.17 & Ultragauge .14 -.15 on my '05 1ZZ-FE.
Does your idle gradually drop to a low point & then exhibit a slight roughness? I always assumed the mixture was intentionally leaned out by the computer to improve idle FE. I recently replaced my intake manifold gasket & idle quality/ low end torque have noticeably improved but still not a silky smooth idle like a Honda 4 banger. MPG seems better too-425 miles & still a little over 1/4 tank left.
05-14-2014, 10:08 AM
#26 (permalink)
Frogger - '00 Honda Insight Gas Only (unHybrid) 90 day: 68.51 mpg (US)
My Neon started out as a big pig. It would start at .45 gph until warmed up, then go between .30-.33. I then cleaned out the AIC valve, which by cleaning, I mean I broke it! After putting it back in, it lowered the idle quite a bit to the point that it has a hard time keeping idle on its own from a cold start... but it would sit around .28-.30! Even still, compared to most modern engines, seems to be more than necessary. Though, I just don't even bother to let it idle just about anywhere anyways (EOC P&G EVERYWHERE!).
As for warmups, my car has had odd cooling issues from the start. When I first rebuilt the engine, silly me put the headgasket on upside-down and it allowed oil to get into the coolant. Since then, I've been struggling to get all the oil out (though nearly 2 years and many cleanout and part changes later, it's far better than it was). In the early life of this engine, it would get up to 220*F pretty easily. Fast forward to now, after extensive grill blocking and a smaller radiator, I struggle to ever see a full warm up! Only on constant steep hills do I ever get into the 195* territory... otherwise, it likes to sit around 180*. This is through 3 different thermostats now! I can only figure that the constant pulse and glide w/ engine off coasting is just too efficient? lol.
05-14-2014, 11:16 AM
#27 (permalink)
Yea it does, the mixture is most certainly not being leaned out. The 1ZZ ECU runs rich if stumbling below idle speed, stoichiometric all conditions from idle up to ~4500rpm or so, and then open loop from there on at high throttle position.
The idle isn't as good as a Honda because the cams are single profile. The 2ZZ has a better idle than the 1ZZ, 7.2mm lift vs 9.4/8.6 intake/exhaust I think explains it. I would love to get a 2ZZ + C60 combo, raise the compression, custom grind the low cam for increased duration and fuel economy, but no money
05-14-2014, 02:17 PM
#28 (permalink)
0.29 Cd and decreasing
My 1998 Honda Civic EX 4cyl 1.6L would be 0.2-0.22gph warm at idle, in neutral, e-brake on.
My 2005 Toyota Tacoma V6 4.0L will be ~0.35gph warm at idle
My 1990 Honda CRX HF...... I have no clue because it's OBD0  I'm guessing it's less than my old civic though.
07-11-2014, 06:56 PM
#29 (permalink)
Zorro - '05 Volkswagen Fox
my consumption goes up when rolling downhill in N
VW fox 2005, 1.6L: 740ml/h (0.19gph) @730rpm, no loads, parked
VW Crossfox 2012, 1.6L: 720ml/h (0.19gph)@710rpm, no loads, parked (just 15000km rolled)
This is what troubles me:
Chrysler sebring 98' 2.5L, 1.3L/h (0.35gph)@ 750rpm, no loads, parked, auto in neutral
Chrysler sebring 98' 2.5L, 2L/h (0.54gph)  @ 1200 rpm, no loads, auto in neutral, rolling downhill @5mph Aprox.
Why does consumption goes so high when rolling? why does it need to raise rpm?
12-06-2016, 06:05 PM
#30 (permalink)
RPM and consumption also increase when rolling in my 1zz-fe Celica, I suspect in order to keep the brake boost and power steering topped up. When stationary at idle, just turning the steering wheel a little increases the rpm a little.
