11-09-2018, 05:32 PM
#201 (permalink)
Hoopie
Shortening wheelbase
I used a couple ratchet straps to hold it together while I measured before welding it together.
11-09-2018, 05:34 PM
#202 (permalink)
Hoopie
Welded together
Here I have enough of it welded together to put it on the lift.
11-09-2018, 05:36 PM
#203 (permalink)
Hoopie
11-09-2018, 05:39 PM
#204 (permalink)
Hoopie
Underneath
Inner frame rail was shortened 11” and fell right into place.
The Following User Says Thank You to Hoopie For This Useful Post:
11-09-2018, 05:41 PM
#205 (permalink)
Hoopie
Underneath
Passenger side frame rail welded in place.
11-09-2018, 05:55 PM
#206 (permalink)
...beats walking...
With HIGH currents thru those ORANGE cables you probably do NOT want to 'loop' them because that turns them effectively into COILS, which can concentrate EMF fields...not a good thing, especially for nearby electronic devices of ANY type.
The Following User Says Thank You to gone-ot For This Useful Post:
11-09-2018, 07:15 PM
#207 (permalink)
Do you anticipate taking orders for these?
11-09-2018, 08:45 PM
#208 (permalink)
Hoopie
I’m thinking of more of a S curve verses a loop.
11-10-2018, 03:40 AM
#209 (permalink)
No worries there. DC current loops produce a constant magnetic field, but a single loop does only provide a very weak field even when the current is high.
Also, the orange tube contains both leads so the fields they produce cancel each other out.
11-10-2018, 01:27 PM
#210 (permalink)
...beats walking...
I wasn't aware there were TWO leads in each of the multiple ORANGE cables, so their fields would indeed cancel each other.
