Old 07-29-2010, 03:28 PM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Hypermiling vs speed bumps
How do I negotiate speed bumps efficiently?
I know - take a route without them.
But what if I don't have an alternative? My neighborhood street has about 6 bumps over 300 meters, some of them quite big. Until now I would pulse, coast, engine brake, roll over the bump, pulse, coast, etc. Sometimes (if there is noone behind me) I pulse to a lower speed and then don't engine brake before the bump. When I can, I go closer to the edge which is lower.
Am I doing it right? Any better ideas?
Old 07-29-2010, 06:24 PM   #2 (permalink)
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
speed bumps? what speed bumps? i ignore them, and replace my shocks and get an alignment every 2-3 years.
i hate doing that to the car but i will not let a sleeping policeman tell me how fast to go.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
Old 07-29-2010, 06:41 PM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
They're a pain.
They wreck your shock-absorbers - meaning your car becomes less safe far more quickly, anywhere else on the road.
They wreck your FE bij forcing a slow down even when its not needed.
They cause more fine dust (from braking , then accelerating again).
They cause excessive noise for the neighbours (suspension, braking, accelerating again)
Hence, they lead to far more pollution than necessary.
I expect we'll see the start of their removal within 5 to 10 years, when the minds of those in charge have finally changed ...
Old 07-29-2010, 07:12 PM   #4 (permalink)
I just drive around them on my bike .
regards
Mech
Old 07-29-2010, 07:30 PM   #5 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Fortunately, speed bumps are very rare outside of parking lots on this side of the Atlantic. I try to hit them at the end of a glide, but I won't brake for them. They're no worse than potholes, which I take at speed as well.
If you drive fast enough, your sprung mass hardly has time to react and you barely feel the bumps. I can't imagine that 40lbs of unsprung mass flapping around puts much wear on the suspension.
Can you rent a heavy plow truck? BUMP - BUMP - BUMP - no more problems for Svietlana.
Old 07-29-2010, 10:15 PM   #6 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Heh, speedbumps at more than 30 in the Jeep can be interesting. You get slammed pretty hard, as being solid axle, it has a lot of unsprung weight. I slow down a bit, to around 20 - 30 mph, depending on the height and length of the bump. I know the suspension can take it, as it's usually pretty smooth if I judge it correctly, and it's a Jeep. However, the obnoxiously sharp (tallish, very short length) bumps in parking lots are usually a crawling affair, as they're too harsh to cross quickly.
I know a guy with a beat up 97 Saturn SL1 who just says "screw it" and takes them at 40+. I've seen him catch air that way , but at least he's not wasting gas (even though that's not his intent).
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 07-29-2010, 11:00 PM   #7 (permalink)
...beats walking...
...where I work, they installed three (3) sets of them (!!!) at all of our entrance/exit gates at different spacings.
...they call them "traffic calming devices"...however, I definitely do NOT feel one-iota CALMER whenever I drive over them.
Old 07-30-2010, 12:37 AM   #8 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
Take them at an angle and you can take them faster. Get left front over the hump before the right front starts up and things work out better. Doesn't work on the ones that are "wide". But the ones that are just a foot or so wide a approach angle will really make a difference. (For bikes approach at 90 angle. But car/truck approach at something less)
Old 07-30-2010, 12:38 AM   #9 (permalink)
Political forces implemented them and political forces can take them away.
But this is like trying to get laws repealed. It's similar to writing something in stone (or graffiti?). Once it is done, it's much harder to get it undone.
Remember, it was probably your neighbors who thought it would be a good idea, petitioned for it and had it enacted - to reduce or eliminate the flow of traffic on "their" street.
Go petition your local legislators against the collective will of your neighbors. Good luck!
Old 07-30-2010, 02:28 AM   #10 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Husqvarna Construction Products Husqvarna PG 3514
rent one of the like and execute a midnight op. Or do it during the day. Wear a vest and have a friend with a stop/slow sign. If you look official you should not receive any trouble.
Note: This suggestion is likely illegal and is made only for entertainment purposes.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
MPG Baseline for Insight 1 Nailed-Long! jime57 Aerodynamics 1 07-24-2010 10:35 PM
Traffic sign placement (aiding hypermiling) Piwoslaw General Efficiency Discussion 7 05-17-2010 12:50 PM
Why Hypermiling With A Radar Detector Is Smart Jammer Instrumentation 25 10-07-2009 02:01 AM
My introduction to hypermiling the Smart Ptero Hypermiling / EcoDriver's Ed 12 10-28-2008 07:32 PM
