Old 11-11-2010, 09:34 AM   #11 (permalink)
BMW has been doing this for like 5 years now. Its nice to see some of the other auto makers are finally catching on.
Old 11-11-2010, 09:50 AM   #12 (permalink)
Pemba - '05 Toyota Prius Package 6
. I am in Mercer Co. WV, on the VA border
Old 11-11-2010, 03:54 PM   #13 (permalink)
...beats walking...
...I recognized the Icelandic landscape (and waterfalls) in the Hydrogen 7 clip.
...Iceland sits on top of a rift between and American and European plates, and has literally "tonnes" of geothermal energy from which to generate electricity, which they use to dissocate water into H2 and O2...
...Iceland is leading the world in use of H2 powered vehicles...all their buses, etc.
...the Hindenburg be damned (ha,ha)!
Old 11-18-2010, 07:51 PM   #14 (permalink)
90 day: 43.3 mpg (US)
Originally Posted by Weather Spotter View Post
My car has one too but that is home made
You home-brewed an active grill block? How did you do this? Now I'm thinking I should design something for my Acura using a servo or something. Realistically I should probably just use a static block.
With our ever-increasing skill at drilling, I wonder if we can ever dig deep enough to tap into this energy here. Maybe someday instead of drilling for oil, the companies will be drilling for heat.
Old 11-18-2010, 10:32 PM   #15 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Here is what I did:
http://ecomodder.com/forum/showthrea...ose-14328.html
Doax has done a fully auto grill block. Mine is opened and closed with a switch.
Old 11-18-2010, 11:21 PM   #16 (permalink)
Here is what I did:
I'll have to read this thread all the way through when I get more time, thanks for the link! So is it imperative to monitor engine temp, or is coolant temp a reliable way to monitor things?
If I got really ambitious and had some time, I'd want to build a carputer and have it actively adjust the grill block. I can dream, I can dream.
Old 11-18-2010, 11:24 PM   #17 (permalink)
Wiki Mod
I use engine and coolant temp interchangeably. On my SG I watch the air intake and water temp.
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
2011 Chevy Cruze Eco / XFE will have 1.4 turbo, 42 mpg (US) hwy rating MetroMPG General Efficiency Discussion 174 02-24-2011 11:09 AM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 12:55 PM
Hyundai Accent Grill Block Spoxxter3 Success Stories 2 08-14-2009 12:01 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 07:00 PM
