Old 07-12-2012, 01:40 PM   #31 (permalink)
Originally Posted by euromodder View Post
The steam also helps to reduce or clean out carbon deposits in the engine, which is also good.
Yes it does.
My engine only had about 6,000 miles on it when I started experementing with water and water/alcohol injection and it made all kinds of strange smells for about the first day. It smelled like fire works being shot off.
The intake manifold remains clean as a watch even with the PCV going into it.
Old 07-12-2012, 02:41 PM   #32 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
so how much water do you to a tankful of fuel
Old 07-12-2012, 04:51 PM   #33 (permalink)
I have mostly tested consumption rates between 1 and 2 gallons of water for each gallon of fuel.
1 to 1 worked fine for my last road trip, the only reason I see to use more than that is for cooling effect.
Water injection - EcoModder
Old 07-12-2012, 07:21 PM   #34 (permalink)
Just some guy
Truck - '08 Ford F350 XLT 4wd 4Dr
Yes it does.
Have you ever had an oil sample pulled? I'd be curious to see whats happening.
08 F350 6.4 PSD IDP Tunes
Old 07-12-2012, 08:46 PM   #35 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I think the only emission equipment my tdi has is the EGR system.
Looking under the hood my tdi seems to be free of all the emission hoses you would normally see.
Save gas
Old 07-12-2012, 09:28 PM   #36 (permalink)
ron
where do you get an oil sample tested . can you mail it to get tested
Old 07-12-2012, 09:37 PM   #37 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Yes, you can mail it out. Just google "oil analysis" and you'll find several companies. I know Blackstone is a popular one.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 07-12-2012, 09:41 PM   #38 (permalink)
I'm not sure about Canadian emissions regs. I think they're basically the same as US, but I'm not sure. In the US, there were no DPFs before 2007. DPF's require ultra-low sulfur diesel (<15 ppm sulfur), which wasn't on the market until the MY 2007 vehicles started coming out.
Diesel Dave
Old 07-13-2012, 05:27 PM   #39 (permalink)
I wasn't planning on it since the oil drain plug magnet has almost nothing on it after every 3k to 4k mile oil change.
I must have built my engine good because I am only seeing 1/3 to 1/4 of the metal shavings I am use to seeing on a drain plug with a new diesel engine.
