Old 07-08-2010, 12:02 PM   #11 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Subaru Impreza Outback Sport
90 day: 27.81 mpg (US)
or just cut the mechanical connection, though it would be nice if I could put things back to stock with ease.
I'll mess with that after coffee.
Old 07-08-2010, 12:14 PM   #12 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
You can always choke the valve by placing a gasket with a smaller hole between the IACV and manifold. That will tame things down.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 07-08-2010, 12:18 PM   #13 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
That probably is the best solution, since the IACV will still work, just with less intensity.
Old 07-08-2010, 12:39 PM   #14 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
No CEL in the truck. I still need to try driving the car with it unplugged. I unplugged it and then started it up and it slowly built revs until I shut it down. Not sure why. I will try it again and drive it.
The truck works great! It almost dies on cold start but a tap of gas will cure that. Not much power on cold cylinders. I REALLY don't like those 2000 rpm on COLD winter starts. It will be getting a switch/rheostat this fall.
The car revs to 3500 rpm to warm up when it is -30° or colder!!!!! NOT GOOD!!!! I don't like to see those kinds of rpm on a cold engine with no oil flow.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 07-08-2010, 12:48 PM   #15 (permalink)
Okay, so with a little googling I've found that my car has a CEL code for the IAB, but the IAB has some manual adjustments... I've got some playing to do, I just wish it wasn't so darn hot and sticky out today...
Old 07-08-2010, 01:07 PM   #16 (permalink)
Team Pontiac
I was looking at my throttle body and I have an adjusting screw for the closed-throttle position. Maybe give it a hair turn?
1991 F-250:
Old 07-08-2010, 01:33 PM   #17 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Turning it up a hair won't hurt. As long as it idles no higher than 850 or so in neutral when fully warm, you're fine.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 07-08-2010, 02:17 PM   #18 (permalink)
Team Pontiac
I will probably turn it up a hair then.
1991 F-250:
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 6 10-07-2013 04:13 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
