05-31-2015, 05:24 PM
#141 (permalink)
The PRC.
Why not just fit a smaller engine ?
06-06-2015, 08:54 PM
#142 (permalink)
Finding an emissions-certified small engine with 2 cylinders that could still move a car decently is not so easy. Anyway, recently I have been thinking about fitting a Harley-Davidson engine into a Subaru Impreza...
06-07-2015, 04:01 PM
#143 (permalink)
The PRC.
No, a smaller engine with a reasonable number of cylinders. E.g. replace a 2.0 4 banger with a 1.3 ?
06-08-2015, 01:25 PM
#144 (permalink)
Where to find a 1.3L engine with less than 4 cylinders? Right now I can only think about motorcycles.
06-08-2015, 02:04 PM
#145 (permalink)
I think he meant WITH 4 cylinders... or maybe three!
This thread makes me wonder about some sort of manually activated VTEC, with the normal cam being very economical and the additional cam giving acceleration power. But I guess VTEC-e is about the same thing. Just make "2-cylinder" the default, and "4-cylinder" the addition.
It might be easier and more effective to build up a low-displacement 4-cylinder with VTEC than it would be to engineer a deactivation system. Maybe a custom crankshaft that limits the range of the piston, and an economy cam that matches the right amount of explosive air to the new displacement... Right? I'm no engineer...
06-08-2015, 03:30 PM
#146 (permalink)
The PRC.
Toyota, Nissan, Peugeot, Ford, GM...
06-09-2015, 01:17 PM
#147 (permalink)
Thalmaturge
The 2003-2005 Honda Civic Hybrid is a 1.3L lean burn. Just pull off the hybrid stator.
Seems like building a injector/timing map for that would be way easier than trying to halve a 2+L engine.
06-09-2015, 02:20 PM
#148 (permalink)
The PRC.
06-09-2015, 02:23 PM
#149 (permalink)
1.0L and 1.2L, but still no 1.3L. Anyway, Nissan has an interesting version of its 3-cyl 1.2L fitted with a supercharger...
06-09-2015, 02:55 PM
#150 (permalink)
The PRC.
I see it's home time in Brazil...
