Old 12-21-2011, 11:22 AM   #111 (permalink)
Well ill be running 4 modules but paired together. How many of these boards would I need
Old 12-21-2011, 11:26 AM   #112 (permalink)
Single phase ac inverter is the application
Old 12-21-2011, 11:31 AM   #113 (permalink)
EVVette - '71 Chevy Corvette Coupe
I would just get 1 board and 2 drivers. This would be the simplest way to do it.
What frequency will you be running?
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 12-21-2011, 11:39 AM   #114 (permalink)
Variable frequency from 60 to 200 hz. Its a tig welder inverter
Old 12-21-2011, 11:44 AM   #115 (permalink)
I'm starting w small stuff to familiarize myself with it.
Old 12-21-2011, 11:59 AM   #116 (permalink)
So are you welding with this circuit or powering a tig welder?
I take it you will be using the output of these 2 half bridge's into a high frequency transformer?
Usually, am inverter tig switch's into a transformer at high frequency and uses the duty cycle and inductance of the transformer to smooth the output and shape the output into more of a sine wave.
-Adam
Old 12-21-2011, 12:04 PM   #117 (permalink)
No I'm using the dc output of our mig/tig/arc welder into the dc bus of the igbts and outputting square wave ac with variable duty cycle to the torch. All the filtering/ foot pedal control will be done with the welder. This JUST inverts the output. simple timing circuit will control driver boards .
Old 12-21-2011, 08:01 PM   #118 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
I still have some IGBT driver boards available.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 12-21-2011, 08:07 PM   #119 (permalink)
And id LOVE to send you a pm about it BUT I can't till I get 10 posts. Howevrr if you'd email me at edmonds22@gmail.com id appreciate it.
Old 12-28-2011, 10:25 PM   #120 (permalink)
Ebay IGBTs, sold as "used in good condition." Uh, yeah.
One of these things is not like the other.
To the sellers credit, they replaced it promptly at zero cost.
The interesting part was opening it up. Death and destruction. I wonder what happened to blow this sucker wide open?
