Old 12-15-2021, 11:55 PM   #21 (permalink)
Originally Posted by Isaac Zachary View Post
The main reason for using diesel fueled HC-SCR is it means you only have to fill up (or fuel up) with one kind of liquid making it more convenient.
Way more convenient. But I remember something about attempts to use ethanol for HC-SCR, yet it still would make more sense to use it on a supplemental injection, which could decrease the NOx formation at the combustion process.
Old 12-18-2021, 04:07 AM   #22 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Getting off topic here, but a diesel exhaust improver that I like, although full of technological hurdles to overcome, is emuslified diesel and water. It's the only method I know of that both reduces NOx and PM at the same time.
Old 12-18-2021, 09:19 PM   #23 (permalink)
I'm only aware of supplemental water + alcohol injection.
Old 12-24-2021, 09:35 AM   #24 (permalink)
To the OP: look at what big rigs do; they will try anything to save money. And check the Renault re20 turbo formula 1 engine. A well crafted equal header exhaust manifold ending on a divided turbine housing will increase spoolup speeds, but the question is always by how much. There is a diminishing return point: the Renault one is much further than yours as a 1s difference in acceleration may win a race. Mercedes has log manifolds in its AMG cars.
Also, check the technical session of https://www.theturboforums.com; there are people there with years working at real companies building intake and exhaust systems. You may find out you will need to start with what is your goal; to accomplish it may require spec'ing out a different turbo.
Old 12-24-2021, 01:41 PM   #25 (permalink)
Twin-scroll turbochargers are not so uncommon, yet dividing a split turbine housing is something I have never seen.
diesel, equal length headers, turbo
