Old 03-12-2009, 09:56 AM   #31 (permalink)
Fokus - '12 Ford Focus SE
90 day: 32.45 mpg (US)
Lecksus - '03 Lexus RX300
90 day: 17.61 mpg (US)
Benzzzzz - '11 Mercedes Benz ML-350 4-Matic
90 day: 18.75 mpg (US)
dremd; True mechanical injection has no electrical input or operation like the Lucas injection (i.e. CanAm 494 Chevy, Formula 5000 Chevy, 1971 Porsche 911E) it has a belt or gear driven pump, throttle linkage controled metering unit, and undividually run high pressure lines to each velocity stack. K-Jetronic is not that type of injection. Mechanical injection has no air density measuring, it is set pretty much on a flow bench or dyno by a tuner or builder. In the case of the street Porsches, this really was true mechanical injection and it was used in a street application till the K-Jetronic injection was interduced. I had one, was really neat injection, nightmare to set up , but ran better than webers (Solexes if stock) and stayed in calibration till you went to a diffrent altitude at which point you had to set it for air density. Once agian K-Jetronic adjusts for this via the air metering unit.
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
Old 04-09-2009, 10:27 AM   #32 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Volkswagen Rabbit S
90 day: 33.97 mpg (US)
Originally Posted by dremd View Post
I don't know about his, but both of the Gasoline Rabbits I have worked on had mechanical fuel injection. ( I *THINK* Bosch K-Jet-Tronic Just like the ones from similar year BMW's).
wow... there did this thread go off too...
EFI was not introduced on North American model watercooled VWs until around 1988 or 89.... Otherwise they were Carbureted in the first 70s models and Mechanical CIS Injection there after (Except some Canada models). Some VW (and Audi) models kept Mechanical injection until the early 90s... namely a lot of n/a 4-Cyl and basically all 5-cyl models.
For those that aren't egumicated on Mechanical CIS Injection.... A Technical Book by Bentley Publishers:
Amazon.com: Bosch Fuel Injection and Engine Management: Charles O. Probst: Books
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 04-09-2009, 12:18 PM   #33 (permalink)
Our 13 year old volvo has done 190k miles on 87 octane with 10.7:1 CR. Its all in the engine management and its ability to adapt.
Old 04-09-2009, 01:37 PM   #34 (permalink)
Manic Rabbit
Southcross's Avatar
already covered page 1, ECU and Knock sensing are two things my engine doesn't have
-Edward
Goal: 4x / 5x
How do you eco-drive a diesel ? groar Hypermiling / EcoDriver's Ed 122 05-24-2014 09:05 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
What's your best bet for an automatic? Crono EcoModding Central 16 10-22-2008 01:14 PM
GAS is 4.50 for Regular in Los Angeles dsq EcoModding Central 10 06-06-2008 03:11 PM
