Old 02-01-2018, 04:56 AM   #1 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
INFINITI Reinvents The Gasoline Engine — VC-Turbo
The Following 2 Users Say Thank You to mikeyjd For This Useful Post:
Fingie (02-02-2018), Joggernot (02-02-2018)
Old 02-01-2018, 07:31 AM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
they've put it in to production? that's good. Now we can see what kind of longevity they will have.
Old 02-01-2018, 11:07 AM   #3 (permalink)
...beats walking...
Uh, an exhaust turbo-charger with controllable waste gate is likewise a 'variable compression ratio' combustion engine...and far less dynamically complicated.
Old 02-01-2018, 12:27 PM   #4 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I don't believe they have released any efficiency numbers yet? Bold claims without data at this point. It may very well be more efficient, but at what cost, literally.
Old 02-01-2018, 02:05 PM   #5 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Personally I think car manufacturers should be spending MORE money on their engines/powertrains and less on "features". Things like variable length intake runners used to be commonplace, but now are usually cut out because it isn't "necessary". Screw that! Just think of how much BETTER it would be! I would gladly pay a few hundred dollars extra for variable length intake runners.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 02-02-2018, 02:40 AM   #6 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Fo you have any specs for these variable intake runners for the diy’er?
Old 02-02-2018, 02:52 AM   #7 (permalink)
The expansion ratio is much higher at low load this way. A normal turbocharged engine cannot have both high power and high mechanical compression ratio.
When the engine is at low load and not developing boost, the low compression ratio really really hurts efficiency because the combustion temperature is low and the expansion ratio is low.
It seems really really complicated but if it doesn't cost them much to build then I suppose there isn't a problem. I personally feel like a better solution is to rev an engine higher when you need power and rely on the transmission to do the downshifting to make that happen, instead of trying to maximize specific torque at considerable expense. Electric motors are the future and electric motors have great instantaneous response so you don't need that low end grunt.
The Following User Says Thank You to serialk11r For This Useful Post:
redpoint5 (02-02-2018)
Old 02-02-2018, 09:51 AM   #8 (permalink)
Daschicken's Avatar
Motorcycle
Motorcycle
Motorcycle
Making your own set of variable intake runners is not really in the scale of the DIY'er, thus why it would be awesome for manufacturers to fit them to engines to begin with! It would be more involved than making a set of headers, so if you haven't done that yet, don't even consider it.
My accord V6 has a variable length intake . It changes the sound enough that it sounds like I have two VTEC transitions, one at 4000 rpm, one at 4900 rpm.
Old 02-02-2018, 10:27 AM   #9 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Do you know the input parameters? I.e lengths and rpm ranges etc?
I am pretty handy sometimes
Could you snap a photo of your intake?
Is it just the intake length after the air filter?
Old 02-02-2018, 11:09 AM   #10 (permalink)
I don't know for sure, but I am going to go out on a limb and say that with variable valve lift and cam phasing, variable intake length may not make a big difference anymore and not be cost effective.
