Old 10-02-2009, 07:11 AM   #11 (permalink)
rusty - '00 ford mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 honda cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 Kawasaki zx10r
90 day: 47.21 mpg (US)
truck - '96 ford ranger
90 day: 26.51 mpg (US)
Originally Posted by Piwoslaw View Post
Yeah, this problem was mentioned on that forum. If the pipe is insulated, then water will still condense on it, but will take much longer to evaporate, and that may lead to corrosion.
Just wanted to make sure.
If I was you I'd leave it alone as is, I think there is a little to be gained in efficiency, and good amount of problems to deal with, just not worth it.
The Following User Says Thank You to nemesis For This Useful Post:
03sl500 (06-29-2010)
Old 06-27-2010, 08:44 PM   #12 (permalink)
HCH II which uses a dual style A/C compressor
Having read through this thread, my question comes more from the A/C maintaining it's cooling effect while in autostop mode. Living in AZ, I use the a/c a lot, and when the car engages the 15 cc electric scroll compressor it just doesn't cool the car while in operation during the summer, especially during the monsoon season (higher humidity). So my question is, insulating the low pressure line, will this help in maintaining the cooling capacity during the electric mode?
Note: this has been an issue since the car was purchased new, not to mention, I've read other blog posts mentioning the same complaint all of which have come from the southwestern part of the country.
Cheers,
Jason
Old 06-27-2010, 09:03 PM   #13 (permalink)
Cheers,
Jason
Set it to recirculate, then turn up the fan. Let the wind chill effect work with you.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 06-29-2010, 07:22 PM   #14 (permalink)
darcane's Avatar
Cheers,
Jason
Again, the only place insulation will help is after the expansion valve and before the evaporator. This likely already has insulation or is so short as to not matter.
Mike
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 06-30-2010, 02:03 AM   #15 (permalink)
Interstellar Clowncar - '00 Honda Insight
90 day: 68.91 mpg (US)
The Beast - '92 Chevrolet S10 Blazer 4D 4x4 Tahoe
Last 3: 15.02 mpg (US)
The Beast 2.0 - '99 Chevy Suburban LS
90 day: 17.54 mpg (US)
What I did was insulate the air chambers to keep the cooled air cool. The housing for the evaporator and the fan are covered in metallic bubble wrap insulation. This gave me a noticeable improvement in vent output temperature (3-5 degrees).
The Following User Says Thank You to azaviator For This Useful Post:
03sl500 (06-30-2010)
Old 06-30-2010, 02:54 AM   #16 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I did this AC mod to my T-100 AC system. I didn't measure the initial temp drop at the time so I don't have true numbers to compare with. I do know my AC cools the truck much better than before.
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 06-30-2010, 10:52 AM   #17 (permalink)
A/C insulating
Azaviator,
Thanks for the response, where did you buy the bubble foil wrap?
Old 06-30-2010, 11:30 AM   #18 (permalink)
Azaviator,
Found it at Home Depot in the Home Insulation aisle.
As a side note, I bought a bit extra (2 of the 10'x2' pieces I believe), and used it to make form fitting window covers. Once they are in, the car is pitch black in the daytime. If I'm going to be parked in the sun all day then I put those in, keeps the car SUPER cool!!!
Old 06-30-2010, 12:34 PM   #19 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I found the same bubble wrap in bulk in both 24" wide and 48" wide at Ace Hardware. It might be another source to check out.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 03:39 PM
It's not just the A/C tasdrouille General Efficiency Discussion 4 04-17-2008 11:57 PM
Riding in cold weather, HELP! NoCO2 Alternative Transportation 16 03-20-2008 11:58 PM
MetroMPG.com mailbag: Metro engine won't stay warm in super cold weather MetroMPG General Efficiency Discussion 13 02-01-2008 11:28 PM
