Old 11-13-2020, 07:55 PM   #3651 (permalink)
SuperTruck Making Leaps in Fuel Efficiency
February 19, 2014
https://www.energy.gov/eere/articles...uel-efficiency
2018
Truck Makers May Test Radically Different Aero Cab Designs With SuperTruck II
https://www.ttnews.com/articles/truc...-supertruck-ii
The primary goal of SuperTruck II is to show a 100% freight-efficiency improvement in a tractor-trailer combination by either doubling the amount of freight that can be hauled with the same amount of fuel, or cutting fuel use 50%, in a representative customer drive cycle over a 2009 baseline, according to DOE.
SuperTruck Program Scores Big, Heads into Second 5-Year Phase
October 31, 2016
https://www.trucks.com/2016/10/31/su...-5-year-phase/
Dubbed SuperTruck II, the five-year, $160-million program will see the same four teams of truck, engine and trailer builders from SuperTruck 1 attempt to move far beyond the successes they’ve already racked up. The teams spent $258 million – a combination of federal funding and their own money – on the first program.
aerohead (11-18-2020)
Old 11-13-2020, 08:05 PM   #3652 (permalink)
https://lynceans.org/tag/doe-supertruck/
aerohead (11-18-2020), Cd (11-14-2020)
Old 11-13-2020, 09:41 PM   #3653 (permalink)
Isn't Starship Initiative the one that had a poster here?
Yes it is: https://ecomodder.com/forum/search.php?searchid=4341504
Old 11-15-2020, 02:55 PM   #3654 (permalink)
https://www.conceptcarz.com/vehicle/...itroen-sm.aspx
Old 11-15-2020, 05:12 PM   #3655 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Found on Instagram
ID:	29565   Click image for larger version
The Following User Says Thank You to Cd For This Useful Post:
Old 11-15-2020, 05:49 PM   #3656 (permalink)
The motorcycle has been posted before, the (Auburn?) I don't know.
Old 11-15-2020, 06:31 PM   #3657 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I have been away from the forum for quite some time.
Should I delete the post ?
Old 11-15-2020, 07:46 PM   #3658 (permalink)
Certainly not.
justacarguy.blogspot.com/search/label/aerodynamics
Old 11-16-2020, 05:19 PM   #3659 (permalink)
Mid-1930s police car doesn't follow the default template:
https://lasmaquinasdelaguerra.files....a-ii-takom.jpg
Those machine guns remind me of a Dalek.
edit: Whelp, there's your problem:
https://g.denik.cz/115/ce/b716c46s-960_galerie-980.jpg
Four wheel steering requires voice coordination. That 8-liter four mounted that high up?
Old 11-18-2020, 11:14 AM   #3660 (permalink)
other two contenders
If we had proper, side elevation views of the two, the Kamm/ Koenig research findings from FKFS would probably supply the numbers.
