Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 03-19-2014, 12:19 PM   #81 (permalink)
The problem with gasoline engines is the more you increase static compression, the cylinder is scavenged more completely. The engine tries to run more efficiently and make more power, but then the throttle gets closed more, lowering dynamic compression, making it less efficient again, because the is no demand for more power.
Thats why compression increases on gas engines net little to no measurable cruising improvement.
If you run a 8:1 compression ratio or 10.5:1 to 1 and reguardless of elevation your dynamic compression is always going to be between 3 and 4 to 1 as you drive down the road.
You need to understand the isobaric expansion process. You have up to 2 horsepower worth of wasted power that can be used to pull air through an air filter or restrictive intake during normal driving.
The idle air control has nothing to do with this.
If you want to play "cram more air into the engine" and have it actually do some good get a diesel. Where more air and clean air filters actually means something.
redpoint5 (03-24-2014)
Old 03-19-2014, 12:22 PM   #82 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 03-19-2014, 06:18 PM   #83 (permalink)
Cool
What we need is someone with a lean burn capable vehicle like a honda to try the air filter switch a roo. I bet with a clogged or simulated clogged air filter lean burn wont be sustainable.
Maybe Ill try wrapped a bag around my kn cai to see how it effects my mpg. Should have zero effect, right?
Old 03-19-2014, 06:38 PM   #84 (permalink)
http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf
If anyone can conduct a better test series than this... DO IT.
Note the results.
If you like, there's more:
http://www.autospeed.com/cms/article.html?&A=111486
Here's another test, but they don't get into the power and fe effects:
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
The Following 3 Users Say Thank You to Frank Lee For This Useful Post:
CFECO (03-19-2014), UltArc (03-28-2014), user removed (03-19-2014)
Old 03-19-2014, 06:57 PM   #85 (permalink)
Funny how a few of the tests showed better mileage with the clogged air filter on the modern efi systems, aka a governor. They restricted the air filter so much on the Lucerne, it sucked the filter out of it's position.
regards
Mech
Cobb (03-19-2014)
Old 03-19-2014, 08:51 PM   #86 (permalink)
mcrews's Avatar
hey frank lee,
your first link is the report that I post in the beginning..at #43.....
ECO MODS PERFORMED:
First: ScangaugeII
Old 03-19-2014, 09:02 PM   #87 (permalink)
Oh, well since the government performed the test we know that went well. It was on a few older vehicles and the test was conducted in 09. It actually showed the dirty or clogged filters gave better mpg, but the conflusion didnt mention it.
Since with the insight ima assist is partly based on petal position I am expected it to actually go up vs down. I pointed that out earlier in this thread and even included photos to show, but guess no one saw it?
Old 03-19-2014, 09:13 PM   #88 (permalink)
Cool
Read both articles. One said its the plumbing to the air box, if not the air box itself. The other said basically that the better filters are more restrictive and a guy who owns a diesel watched them put the filters on a testing machine for filters and filtration testing.
When I quit noticing an improvement Ill quit buying them.
