Old 10-18-2009, 02:49 AM   #1 (permalink)
Kadet E GT EV Conversion
Hy all
i just bought this "beast"
960 kg / 115hp / and an echonomical 20l/100km
hope to become an nice ev
planned components
drive:
motor warp 9"
paul's 500A controller
10 GEL forklift batteries
chargers
DIY charger
solar pannels
small 2 kw generator (petrol) for extended range or fast charge
ID:	4525Click image for larger version
ID:	4526Click image for larger version
Old 10-18-2009, 02:52 AM   #2 (permalink)
Hey look its already a EV it has a battery charger hooked to it...
Kidding. Keep the info coming...
Dave
Old 10-30-2009, 06:44 AM   #3 (permalink)
update
the car is at the boday shop for repairs
in the meantime
we have ordered the comtroller (thanks Paul)
and the motor (thanks Netgain)
we have started the gas peddal conversion (pictures will follow)
gas pedal is based on clasic design with cable and an 5k variator
for batteries we plan to use 10 calcium batteries (around 100 EURO)
SLA 75 wich will give is around 100km authonomy
found compatible chargers for 144v list atached (can be used as guide for our charger)
different batteries and chargers brochure atached including cheap calclium batteries
Hotfile.com: One click file hosting
found digital scope and pannelmetters for replacing old metters on car
those fit perfect replacing old ones
atached also here / maybe are usefull for others
secondary solar charger ....
secondary gas generator ....
to be checked for performance
Old 11-12-2009, 02:50 PM   #4 (permalink)
progress
DONE
signal lamps are now leds
original lamp was using 25w lamps
led lamps use 7 12v leds 0.6W all (0.047A measured for the 7 leds)
price 10USD / Lamp
TODO
building signaling circiut because old relay will not work due to low current
UPDATE
i have found and ordered 100x150 cm of fotovoltaic cells for roof
200 USD for all
will see the test for performance
from diagram each cell is 36v/7A
rear lapmps conversion
will follow shortly
ID:	4726Click image for larger version
ID:	4727Click image for larger version
ID:	4728Click image for larger version
ID:	4730Click image for larger version
ID:	4731Click image for larger version
ID:	4732Click image for larger version
Old 11-13-2009, 03:31 PM   #5 (permalink)
work started to rear lights
but unforunately stoped for 1 week
i need more leds
for now only rear light is working
calculated cost 30 USD/lamp block
tests
rear light 100 mA (0.1A)
original light bulb 21W
rear signal light 100 mA (0.1A)
rear brake/position 100mA+50mA (150ma)
original light bulb 21W/5W
ID:	4739Click image for larger version
ID:	4740Click image for larger version
ID:	4741Click image for larger version
ID:	4743Click image for larger version
ID:	4744Click image for larger version
ID:	4745Click image for larger version
Old 11-14-2009, 09:08 AM   #6 (permalink)
new signal relay is ready
original diagram was published on tehniq
i have modified it for our needs
biggest current is 50mA x4 when all 4 lamps are lit
so max current must be arroud 200 mA
i took 1A to be shure so for command i used an BD237
Q1=Q2=BC171
Q3=Q4=Q5=BD237
and also i have atached my simplified diagram
price for simplified diagram 3USD
ID:	4754Click image for larger version
ID:	4755Click image for larger version
Old 11-17-2009, 04:03 PM   #7 (permalink)
solar pannel has arrived
36v 7A on load (252W real/250W rated) so i will need an dc2dc conv for 144v
dimendions 1000x1500x5 mm
price 200USD
will replace car roof and blend into the car
update
i will change the
with
36v 5A on load (180W real/180W rated)
dimendions 900x1100x5 mm
price 180USD
because the big one cant fit on the top of the car
and add an new one on the hood later
ID:	4768Click image for larger version
Old 11-18-2009, 03:09 PM   #8 (permalink)
update
buyed 4 rims with new tires for the car
195x50x15"
12kg each new tire+rim
searching for an new carbon hood to be lighter than existing one
searching for new bumpers
Old 11-18-2009, 03:40 PM   #9 (permalink)
EcoModder Student
esoneson's Avatar
Originally Posted by jerpelea View Post
update
195x50x15"
Wow, you don't stand in one place long do you?
Keep 'em comin' jerpelea, you be Mr. Dynamo!
Eric
1995 BMW 318i EV in the making
Old 11-19-2009, 12:17 AM   #10 (permalink)
info update
car is at car repair and is coming along nice
now being disasembled and cleaned for rust
after some searches for electrical part we need
1.dc-dc converter 36-144v (500W)
2.ac-dc converter for 110/128v generator (5Kw)
so we need to buy/build them
i have found an drawing of what i want it to look
(bumpers and dors )
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
1995 Toyota pickup EV conversion... ModelE EcoModding Central 13 01-05-2010 11:08 PM
Ford Explorer EV Conversion in MA Matt Herring Fossil Fuel Free 0 05-19-2009 12:10 PM
Riley's EV conversion WannabeEVer Fossil Fuel Free 3 06-28-2008 12:47 PM
Practical? Possible? Taurus EV Conversion WaxyChicken Fossil Fuel Free 30 01-17-2008 11:12 PM
