Old 11-27-2009, 03:39 PM   #21 (permalink)
also 12v-220v inverter (500W) has arrived
it will be used for solar pannel chardger (240W/h top)
pictures atached
i will need to remove some cooper from transformers (2x 12/220v - yellow ones) to get 144v but now is working on 220v
for now i have plugged 300W halogen lamp and convertor is working nice
i have top 240W from solar pannels so is enough for me
for test the converter is plugger afer the modified computer power supply and i have tested both and are working nice
i am wainting for new solar pannels to test it in real life
this converter also needs an new sealed case made from cooper and i need to remove the fan
ID:	4851Click image for larger version
ID:	4852Click image for larger version
Old 11-30-2009, 07:19 AM   #22 (permalink)
in car panel computer
modified eeepc 701 4G 7" display
can be used to get real time data from controler using RTD Explorer
power used less than 12W
can be foud on ebay around 100USD
now i need to find an case 225x140x40 for pc (i will use eepc LCD frame)
i have ordered an touchscreen interface so thet you can access menus and type without keyboard price 30usd
ID:	4941Click image for larger version
ID:	4942Click image for larger version
ID:	4944Click image for larger version
ID:	4945Click image for larger version
ID:	4947Click image for larger version
Old 12-09-2009, 03:13 AM   #23 (permalink)
update
144-12v 2x17A converter is almost ready (now packing in case for car instalation)
144-12v 4A for computer and controllers is ready (now packing in case for car instalation)
12-144v 500W inverter is ready (fets changed,transformators rebuilt) (now packing in case for car instalation)
220-144v car charger (testing small scale)
10-12batteryes BMS is ready (in testing phase)
car computer is almost ready (waiting for touch screen)
i will updload pictures later
ID:	4999   Click image for larger version
Old 12-11-2009, 02:22 PM   #24 (permalink)
dc - dc converter is ready almost finished assembling it
now we have the down converters ready
144-12v 17x2A for lights and breaking pump
144-12v 4A for pannel computer and controller
2 independent converters in the same box
i have removed impute ac-dc bridge and i am injecting dc directly into it
i have also moved all power components to the big aluminium heatshinks
ID:	5005Click image for larger version
ID:	5007Click image for larger version
Old 12-12-2009, 10:28 AM   #25 (permalink)
waiting for the rest of parts
for now working on batery monitor
we need to know if batteries are leveled so me measure each batery and use an 10 led bargraph to indicate its state
10 identical 12V bargraph voltmetters based on lm3914
bargraphs are easy to read when driving !
we have an digital volmetter to measure battery pack voltage (whole pack)
and this bargraph to measure the remaing power for each battery
we have chosen 10 leds bargraph (DC10GWA) with last 3 red to know when the batery is nearly deplition (11.2V) so that we will not destroy the battery
also voltage levels can be ajusted individualy
for separation we have used quadruple optocuplers (3 of them) to be shure that high voltage can not break anything
this can be mounted on secondary radio bay or in our case in the center on console (where were old warning lights for preasure,etc...)
cost for the whole 10 voltmetters is around 20USD
ID:	5011Click image for larger version
Old 12-13-2009, 11:47 AM   #26 (permalink)
DYI Dolar charger
i blew the chinese 500W converter at tests with 200W halogen bulb in around 2 hours
upset i decided to build my own
it consists in 3 blocks
clock generator with 555
flip flop switch 1/2 of 4013
power block 2 BUZ48 for every 250W of load
i have reused the old ferite transformer and rewired it for my needs
i have tested this converter with 200W load for 1 day and is still working
(not from the test battery but from my 12V 2x17A dc source )
for battery charger it needs an ac/dc rectifier and an operational as comparator (to monitor charging currrent and stop charging at full battery)
final one has 4 fets (to be shure that it resists in time and prevent overheating)
i have also added 2x200cm2 aluminium raditors
now everthing stays at 43C
price 18USD
ID:	5014Click image for larger version
ID:	5016Click image for larger version
ID:	5018Click image for larger version
Old 12-13-2009, 11:55 AM   #27 (permalink)
PaulH
MPaulHolmes's Avatar
This guy doesn't waste time!
kits and boards
Old 12-13-2009, 12:57 PM   #28 (permalink)
Start investgating cheap/small brake pump
i have used an tire compresor that can go to 12 atm and reversed the valve
now i am searching for an vacuum tank 1-2l so that we can stop the pump and start it only when preasure goes below 4atm
the pump is realy small 80mm by 35mm and realy quiet (can be heard )
cost of pump with gauge 7 USD
ID:	5020Click image for larger version
Old 01-16-2010, 12:42 PM   #29 (permalink)
finaly some progress
car came from painting ...
now the real work begins
ID:	5361   Click image for larger version
ID:	5362   Click image for larger version
Old 01-16-2010, 12:48 PM   #30 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
that looks great!
single person car thread
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
1995 Toyota pickup EV conversion... ModelE EcoModding Central 13 01-06-2010 12:08 AM
Ford Explorer EV Conversion in MA Matt Herring Fossil Fuel Free 0 05-19-2009 01:10 PM
Riley's EV conversion WannabeEVer Fossil Fuel Free 3 06-28-2008 01:47 PM
Practical? Possible? Taurus EV Conversion WaxyChicken Fossil Fuel Free 30 01-18-2008 12:12 AM
