Old 08-19-2015, 11:59 PM   #11 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
read this thread for some good info. reflectors have a LOT to do with pattern.
http://ecomodder.com/forum/showthrea...ing-31942.html
Originally Posted by brucepick View Post
Scott,
......But I think I can live with it as long as the pattern is better than the do-it-yourself cheapie HID conversions that glare in my eyes every day..... .
those HID's in the eye are from morons putting them in a housing/reflector that wasn't designed for them.
That is a 300 watt LED light bar...............
If its not bright enough just add a second one.
here's a good place to get some, lower watt/lumen but also lower price than most i've seen. i have made multiple orders from them and have been more than satisfied.
don't know how much that one cost but here is one i have in my wish list that's sold out but a search will find more:
http://www.dx.com/p/52-300w-cree-xb-...9#.VdVRIZdtFwU
smaller lumen:
http://www.dx.com/p/guleek-40w-3000l...4#.VdVSZpdtFwU
http://www.dx.com/p/lml-1748-waterpr...8#.VdVREJdtFwU
http://www.dx.com/p/b-45f5-45w-3370l...6#.VdVRNZdtFwU
http://www.dx.com/p/7-7-36w-cree-xb-...3#.VdVROpdtFwU
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 08-20-2015, 05:28 AM   #12 (permalink)
90 day: 29.78 mpg (US)
I'm noticing the before and after exposures aren't the same. In the second photo, the sky and trees are brighter, suggesting the shutter or ISO sensitivity was increased to capture more light. Probably a fine light bar, but it annoys me when advertising uses shenanigans.
The Following 5 Users Say Thank You to redpoint5 For This Useful Post:
AbramWagner (08-20-2015), digital rules (08-20-2015), Gasoline Fumes (08-20-2015), jakobnev (08-20-2015), PaleMelanesian (08-21-2015)
Old 08-20-2015, 02:06 PM   #13 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
For $10 more, a little work, and the peace of mind of DOT approval, get these instead:
2015 Murano LED Projector System - Closeouts
OEM LED headlights (low- and high-beam) from the 2015 Nissan Murano. Each LED is 11w; I ordered a set today and am going to try retrofitting my stock headlights.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
deejaaa (08-20-2015)
Old 08-20-2015, 02:44 PM   #14 (permalink)
Not banned yet
deejaaa's Avatar
that IS a great price and the cut-off looks good. i would like to get a set for me to try but can't right now. maybe in a couple of weeks. i will buy a set of lights cheap off CL or JY so i won't be without them while i fit them in. thanks for the info.
Old 08-20-2015, 04:31 PM   #15 (permalink)
I don't know how good of a light bar it is. At only $100 and 52'' long, its hard to say. But it doesn't come with any switches, wires or relays.
I would likely go with a curved, 100 watt bar and whatever it is, it has to be less than 48''.
Yeah I was looking at that after I posted this picture I noticed other light sources appeared brighter.
If a light bar manufacturer claims 30,000 lumens, even if its really only 20,000 lumen that still like adding 20 halogen head lights to the front of your car.
I use two 20 watt LED flood lights and it lights up my most of my 1/3 acre front yard. This is 7.5 times that wattage of my flood lights.
Old 08-20-2015, 05:37 PM   #16 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
The beam pattern is so wide and tall you could never turn that thing on when on a road with other cars around.
Old 08-20-2015, 07:33 PM   #17 (permalink)
Moderator
Vman455's Avatar
I got on there the other day after one of these LED threads popped back up just to see what they had (they've had Prius LED assemblies for sale in the past, so I check occasionally). I was surprised to see these, and apparently they have hundreds of them. Looks like they'll be a lot easier to retrofit than the Prius LEDs to boot, and the fact that you get high beams too makes them a great deal for the price.
Old 08-20-2015, 08:34 PM   #18 (permalink)
Here's a field expedient fix for the LED in an H-4 reflector. I held a piece of cardboard in the beam to judge placement. I though covering the bottom would do it; but it turned out to be the top.
Old 08-20-2015, 08:49 PM   #19 (permalink)
Not banned yet
deejaaa's Avatar
can you get a night shot on a wall?
Old 08-20-2015, 09:01 PM   #20 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I'm sure they're ideal for the vehicles they are built for.
Mine is a '96 Accord.
Coast long and prosper.
led bulbs, led headlight, led headlights, xenon depot
