Old 04-25-2018, 10:00 AM   #21 (permalink)
Using my Ultra Gauge, I have taken some fuel flow rates at a selection of idle speeds.
Engine Fuel MAP
Speed Flow
(rpm) (G/hr) (psi)
750 0.14 3.8
1000 0.17 3.48
1250 0.21 3.34
1500 0.23 3.05
1750 0.29 3.19
2000 0.31 3.19
As my car has a MAP sensor with no MAF, the Ultra Gauge appears to assign a VE of 75% across the whole load/speed range and then calculates the air flow based on the manifold air density and this assumed VE. The fuel flow is then proportional to the air flow.
I am curious if any North American owners have measured idle fuel flows as their cars have a MAF sensor and thus the fuel numbers should be more accurate?
Old 05-12-2018, 09:44 AM   #22 (permalink)
Mirror Delete
Deleted passenger mirror today and subsequently got a new mpg best on a 14 mile out and back trip that I have driven approx 10 times in this car. I always glide on down slopes when I can on this route as the traffic is very light.
New best 69.11 mpg US / 83 mpg IMP / 3.4 lit/100km
Engine started from cold - 62 oF water temp
Previous best on this route was 64.95 mpg US / 78 mpg IMP
The car appeared to glide with less retardation in speed compared to normal.
Just need some white insulation tape now to replace the green!
ID:	24163   Click image for larger version
Old 05-12-2018, 10:20 AM   #23 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by cr45 View Post
... Just need some white insulation tape now to replace the green!
Nice updates. Instead of tape, you might make a filler plate out of a white or gray plastic, prime it, and paint it an OEM white if you want maximum stealth. Alternately, a black plate to look like trim. There are examples of the builds already on EM. Search top left.
Did you get the lithium? How is it going?
Old 05-13-2018, 04:43 PM   #24 (permalink)
New Absolute best mpg - 76.44 US mpg
Noticed there was next to no wind this evening and decided to take the car on a 22 mile circular route - non stop.
Used pulse and glide and a 42 mph top speed.
Engine was idling during glides.
Parked up on 76.44 mpg US / 91.8 mpg IMP / 3.077 lit/100 km
This is equivalent to a diesel doing 2.797 lit/100 km from both a thermal efficiency and a CO2 point of view.
