Old 02-01-2009, 05:43 PM   #11 (permalink)
90 day: 51.82 mpg (US)
Fortunately, the Suzuki 993cc engine in the Metros are non-interference.
Old 02-01-2009, 05:58 PM   #12 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
One of the things I am planning when I finally get around to the head swap in my car was getting weaker springs. With the way the engine is tuned right now I can't really get the engine to redline anyway the top end is totally weak. I get the best power shifting at 3500 so if I find a set of springs that will float at 3750 I am set
I have a pile of Metro springs sitting around I just have never measured one to see what size they are so I know what to order to replace them. If it ever gets warm here I might get out there and work on something.
The Following User Says Thank You to Coyote X For This Useful Post:
aerohead (11-23-2015)
Old 02-01-2009, 06:42 PM   #13 (permalink)
Even so, spring bounce is a bad thing. Pains must be taken to hold revs below that threshold. That probably means an electronic rev limiter of some sort.
Old 02-01-2009, 11:31 PM   #14 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Desmodromic valve actuation is a maintenance nightmare. Also running two valve trains probably exerts more drag than stiff valve springs.
You probably could lighten up the springs if you slowed the engines down from the howling RPM most small engines turn.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 02-02-2009, 12:24 AM   #15 (permalink)
That raises the question: how much internal friction or HP savings is there with lighter springs?
Old 02-02-2009, 12:49 AM   #16 (permalink)
That would depend on if were talking flat tappet lifters or roller lifters.
Old 02-02-2009, 12:51 AM   #17 (permalink)
OK even so...
Old 02-02-2009, 05:29 AM   #18 (permalink)
The Ducati Desmodromic system can be spun on the test bench with a snap of the fingers...literally.
Inertia keeps the valves moving quickly enough to seat fully even at idle speeds to eliminate the need for springs which the Mercedes cars used in the late 1950's.
Maintenance isn't a headache BUT you must know what you are doing , it take a lot of time AND it is very easy to get it wrong.
For the consumer this means higher service costs which not all are prepared to pay.
For Ducati it is as much a sales tool as it is an efficiency concern.
Look at the number of bikes not using it and that becomes very clear.
At the moment Ducati are the only builders using that system.
Pete.
Old 02-02-2009, 05:37 AM   #19 (permalink)
Frank ,
I recall reading a statement giving the numbers around 25% of engine power but I am unable to find the source.
Pete.
Old 02-02-2009, 05:47 AM   #20 (permalink)
OK Found it after all.
The numbers are lower than 25% and are reported as 19%
A quick copy / paste of the abstract is below:
Engine friction lubricant sensitivities: A comparison of modern diesel and gasoline engines
R. I. Taylor
Shell Research and Technology Centre, Chester, UK
Abstract
Engine friction models have been developed that take account of the variations in lubricants with temperature, shear rate, and pressure. These models have been used to study the lubricant sensitivities of modern diesel and gasoline engines. Total engine friction losses for a Perkins Phaser four-cylinder, 4.0 l, turbocharged, inter-cooled diesel engine, operating at 1300 rpm, with an SAE 15W-40 lubricant, were estimated at approximately 2 kW, with the piston assembly contributing 46%, the bearings 49%, and the valve train 5%. Total engine friction losses for a Mercedes Benz M111 2.0 l gasoline engine (used in CEC sludge and fuel economy engine tests) operating at 2500 rpm, and medium load, for an SAE 15W-40 lubricant, were estimated at 1.5 kW, with the piston assembly contributing 42%, the bearings 39%, and the valve train 19%.
Pete.
The Following User Says Thank You to Peter7307 For This Useful Post:
seifrob (11-24-2015)
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
