06-28-2022, 09:48 PM
#171 (permalink)
Hub motors.
06-29-2022, 03:08 PM
#172 (permalink)
Originally Posted by samwichse
$265k tho. Might as well be on Mars for me.
It is a limited production "statement" car. They are aiming at a $30K car next.
06-29-2022, 04:56 PM
#173 (permalink)
The first run of Arcimoto FUV went for $40K, they're currently at $17.9K, with a target of $10K for the FUV and $2-3K for the MLM.
$265K/10 is a big jump.
09-15-2022, 08:27 AM
#174 (permalink)
Mechanical engineer
The Following User Says Thank You to Vekke For This Useful Post:
09-15-2022, 08:48 AM
#175 (permalink)
Originally Posted by Vekke
They duck-taped the whole car! Sure they have lowest Cd.
11-30-2022, 09:41 AM
#176 (permalink)
Lightyear 0: Production has just started!
As previously announced, the Lightyear 0 has gone into production at the Valmet plant in Finland
https://lightyear.one/articles/impac...nto-production
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
12-01-2022, 01:42 AM
#177 (permalink)
could one say the rear has a mini box cavity since the hard separation edges extend out a little bit?
The Following User Says Thank You to Phase For This Useful Post:
12-01-2022, 10:46 AM
#178 (permalink)
'box-cavity'
A box- cavity would have no exterior 'surfaces', as on the Lightyear's tail-end, just open 'cells' defined by longitudinal 'rib-sections' bounded by one inbound 'wall.'
12-01-2022, 11:10 AM
#179 (permalink)
'Cd 0.175'
* The Lightyear has a fineness-ratio of approx. 3.3243, and Cd 0.20/ 0.175, and conforms to the AST-II, and diffuser angle of 15.5-degrees.
* Lightyear's 'next door neighbor', the GM Aero 2002/ GM Aero 2003A, has a fineness-ratio of 3.3320, and Cd 0.14/ 0.13-something, and conforms to the AST-III, with a diffuser angle of 11-degrees.
* The Lightyear-One has vestigial rearview side mirrors/cameras.
* The Lightyear- Zero abandons the side mirror location, and moves camera pods into the wake of the front wheel arches.
No idea what the tires size is.
No idea if the 'taped' car Cd reflects the 0.175.
No idea if Cd 0.175 is a 'crosswind-averaged' value.
* The GM Aeros are 'mirror-less'
* Their tires may be as narrow as 145mm, which, according to Pontiac Trans Am testing, compared to the 195mm section of the Citation-IV, would provide a Cd 0.025 drag reduction.
* GM's development testing of the GM EV1/ 1999 Precept concept indicated side mirror drag of Cd 0.015.
* 'Features drag' of the Precept was Cd0.0000 ( all cut lines and gaps taped over made zero difference).
Reason: typo
12-01-2022, 02:18 PM
#180 (permalink)
So what’s the term for the rear edges that slightly extend out then cup back into the rear? Hyundai seems to call them “ separation traps” and a lot of the newer Toyotas have something similar below their tail lights. Eqxx and xl1 also so something similar at their rears too
