Originally Posted by blimo
Do you think think you could use this process to fab up some foam blocks that would form a smooth belly pan and be removable?
It would be difficult to execute since you would need to inject/pour the 2-part foam in hard to reach spots. I can't even imagine the amount of time required to prepare the area as 2-part foam can be quite messy.
It can be done but it will require lots of time, especially since you cannot flip your car over to make the process a bit easier !
