Old 07-14-2012, 06:04 PM   #141 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Currently re-working the surface of the grille blocks. Stone chips and previous surface imperfections need to be fixed.
Old 07-14-2012, 06:51 PM   #142 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
did you ever fix the wheel covers? I used steel then they rusted to badly in MI so I went with aluminum ones from amazon $7 each.
Old 07-14-2012, 07:04 PM   #143 (permalink)
CigaR007's Avatar
I didn't fix the steel wheel covers since I installed my summer wheels. I do plan on removing the surface rust and applying a protective coating. I only use the covers during Winter since the air is denser..
Do you have the link for the aluminum covers ?
Cheers !
Old 07-14-2012, 07:15 PM   #144 (permalink)
Wiki Mod
what size do you need?
I use mine all year around (set for each set of rims) and summer testing showed a 1.5 MPG gain at 55 MPH.
Winware 16 Inch Aluminum Pizza Tray with Wide Rim: Amazon.com: Kitchen & Dining
now only $5 each and I found the 16" to be dead on 16"
Old 07-14-2012, 07:16 PM   #145 (permalink)
CigaR007's Avatar
My winter rims use 14" hubcaps. I am assuming I would need a 15" pizza pan to completely cover the hubcap ?
Old 07-14-2012, 07:43 PM   #146 (permalink)
Wiki Mod
Do you have a tape mesure?
My 16" rims needed 16" pizza pans and 16.5" would have been better.
Old 07-14-2012, 07:52 PM   #147 (permalink)
CigaR007's Avatar
Will check it out. How are they in regards to weight ?
Thanks again !
Old 07-14-2012, 08:14 PM   #148 (permalink)
Wiki Mod
not very heavy at all. Amazon page said 4 oz each.
Old 07-14-2012, 09:52 PM   #149 (permalink)
Foam Belly pan?
Do you think think you could use this process to fab up some foam blocks that would form a smooth belly pan and be removable?
Old 07-15-2012, 11:22 AM   #150 (permalink)
CigaR007's Avatar
It would be difficult to execute since you would need to inject/pour the 2-part foam in hard to reach spots. I can't even imagine the amount of time required to prepare the area as 2-part foam can be quite messy.
It can be done but it will require lots of time, especially since you cannot flip your car over to make the process a bit easier !
aero mod, grille block, toyota echo
