Old 10-18-2015, 01:38 PM   #171 (permalink)
The teardrop shape has it's widest section ahead of the midpoint. It's generally a 30/70 split. That means you can sort of bury the front suspension, but the body needs to taper before it gets to the rear wheels, which is a problem.
thank you! i understand it now.
so the nose has to be rounded?
the nissan delta wing nose is poorly designed?
Old 10-18-2015, 03:23 PM   #172 (permalink)
some sketches:
is that the final shape?
Old 10-18-2015, 03:48 PM   #173 (permalink)
downforce mode on:
Old 10-18-2015, 04:06 PM   #174 (permalink)
The Nissan delta wing nose is un-necessarily long. If it was blunter you could meet the 16° approach angle with a lower stagnation point.
You keep reverting to that high nose. It needs to be like a Porsche 356 with a baby buggy bumper. Or the second picture above.
If you make a single form and fabricate two sides from it, you could fur out the front to get the taper you need.
For the nose, why reinvent the wheel?
Proline Racks: Yakima SkyBox 16,18 and 21 Roof Boxes
These come in three sizes 36" wide by 15-18" tall (914.4x381-457.2mm). I have one of these that's bigger but shorter I bought cheap used. This style is intended for skis. It would need beefed up attachment points and (being thermoplastic) it would explode in a collision.
While I was looking for an illustration, I ran across this:
http://www.akmining.biz/snow/snowcoach_by_equinox.htm
Now this is made of polyethylene and it would be like riding in a big crash helmet.
___________
How much of a boat tail can you squeeze into the rules?
___________
Edit: I see your cross-post. You're putting wings on an open wheel car. If you could figure out how to make a panted, cycle-fendered wheel that created the downforce it would apply directly to the tire's contact patch. I don't know what that would look like.
___________
Boat tail.
Old 10-18-2015, 04:26 PM   #175 (permalink)
___________
___________
___________
Boat tail.
-ok, i will redo the nose and make it lower.
-you are suggesting to use an existing form? like the sky roof rack box?
-the boat tail is only limited by total body length: 2300mm but also limited by my pickup truck bed . maybe the boat tail can be a separate piece, for making the transport easier.
-Adding wings was just a joke, but what you mean by cycled-fenders?
Old 10-18-2015, 04:33 PM   #176 (permalink)
this nose is better?
Old 10-18-2015, 05:25 PM   #177 (permalink)
Use the roof box directly instead of as a form. Cut the driver position into the back, gusset it appropriately and have 6-8 fasteners to remove it.
You could use a roof box as a boat tail, as well.
Downforce cycle fenders was a joke.
Edit: the nose is better IMHO. Think about a U-shaped clear plastic hatch that hinges open for ingess/egress but fits closely round the helmet just below the eye-slot. If you didn't have the helmet it would knock you teeth out, but the helmet is required. Just make the plastic edge weaker than the helmet.
Old 10-19-2015, 03:07 PM   #178 (permalink)
i have already started!
Old 10-19-2015, 03:16 PM   #179 (permalink)
PSmodder lurker
...use spray foam too.
Old 10-19-2015, 03:43 PM   #180 (permalink)
Yikes!
aero, low drag, soapbox, streamlined
