Old 11-10-2015, 01:07 PM   #201 (permalink)
That would depend on the angle, more upright and bluff will have less lift.
I think you were on the right track back in Permalink #131
To address the high stagnation point (the point where air can't decide to go up or down) add a crushable chin spoiler.
i think that the actual shape is very similar than Permalink #131:
to reduce lift some kind of splitter can me made:
The Following User Says Thank You to orengomotors For This Useful Post:
aerohead (01-06-2016)
Old 11-10-2015, 04:57 PM   #202 (permalink)
drag
Sorry! Got caught up with the lift aspect.
#1 has the highest drag
#2 and #3 have the same drag
#1 is the worst as far as lift
#5 produces the most downforce
Between #3 and #4 you'd hit neutral lift.
orengomotors (11-10-2015)
Old 11-10-2015, 05:23 PM   #203 (permalink)
woow so it's the worst shape possible?
Old 11-10-2015, 05:45 PM   #204 (permalink)
shape
The low stagnation point,sweptback nose,called 'Stromform' by a bus company in Germany which used it,repeatedly shows the lowest drag and is the easiest to control front lift with.
It's a 'blunt instrument',but for subsonic flow,it has advantages over many other designs.
Hucho has illustrated it's benefits
Here,R.G.S.White shows it as the lowest drag nose in his MIRA research of 1968
Here's HONDA's solar racer using it.Cd 0.10
It dates to 1922,with Paul Jaray's Zeppelin-inspired 'pumpkin seed.'
It's been considered 'ideal' ever since.
Old 11-10-2015, 09:54 PM   #205 (permalink)
Except it will try to burrow under anything it runs into.
It's also important to be able to paint a shark-mouth on it.
bikeprof (11-10-2015), orengomotors (11-11-2015)
Old 11-10-2015, 11:03 PM   #206 (permalink)
Wannabe hyper..., miler !
bikeprof's Avatar
White Variant - '96 Volkswagen Passat TDI ~ GLS- 4 Cyl
Minivan - '96 Chrysler handicap IMS built LXI
Insight - '10 Honda Insight EX
Originally Posted by orengomotors View Post
i have already started!
HAHAHAHA, looks like my room in college days 😳 !
Old 11-10-2015, 11:11 PM   #207 (permalink)
bikeprof's Avatar
1. Hard to "re-invent the wheel"
2. FISH, think like a FISH
3. Only the front can be blunt/sharp/flat BUT rest HAS to be smooth with the % of previously studied aerodynamics designs
4. Like the song; "Get Down"...
The lower, the better. So lay down/stretch the frame like Bonneville cars
Mucha suerte y gana para nosotros... ��
Old 11-10-2015, 11:19 PM   #208 (permalink)
bikeprof's Avatar
Quoth Google: "expressing shock and alarm, often for humorous effect."
Many TV shows on AMERICAN idiotboxes when Walt Disney was alive HAD that action term ��, YIKES...
Because shortly before or after, something was to happen! ��������������
Old 11-11-2015, 12:17 PM   #209 (permalink)
hmmm, shark-mouth
The Following 2 Users Say Thank You to orengomotors For This Useful Post:
aerohead (01-06-2016), freebeard (01-06-2016)
Old 01-06-2016, 11:36 AM   #210 (permalink)
I'm Back!
I had some school work but now it's over.
Well, the foam mold project didn't work very well so i decided to do something different:
What do you think? it's better than when i posted the first picture on this forum?
I also Installed some 6 point harnesses for safety reasons.
The Following 3 Users Say Thank You to orengomotors For This Useful Post:
aerohead (01-06-2016), BamZipPow (01-06-2016), Joggernot (01-07-2016)
aero, low drag, soapbox, streamlined
