Old 02-09-2016, 06:46 PM   #241 (permalink)
But the Rumpler does pretty good with it.
Old 04-04-2016, 05:28 PM   #242 (permalink)
Well after doing 2 races i can say that the front bodywork WORKS. Now i feel more the air into my face.
In the other hand i failed to make more roundish those edges i only was doing ugly vents to the metal.
The Following 2 Users Say Thank You to orengomotors For This Useful Post:
Joggernot (04-05-2016), Xist (04-05-2016)
Old 04-04-2016, 07:53 PM   #243 (permalink)
Flying!
Old 04-05-2016, 12:59 AM   #244 (permalink)
Heh. Loose straw on the track.
Somebody's been in the hay bales.
Old 04-05-2016, 02:55 AM   #245 (permalink)
It's Downy soft!
Old 06-29-2016, 12:21 PM   #246 (permalink)
It's been a long time!!
i had no time because the university admission exams but those last days i had been modifying the suspension.
First i designed a new geometry:
Next i started to build it:
And finally, doing the pushrod system, with a smaller, thinner rod than before (small aero benefit here! ):
The Following 4 Users Say Thank You to orengomotors For This Useful Post:
aerohead (06-29-2016), freebeard (06-29-2016), Joggernot (06-29-2016), Xist (06-29-2016)
Old 06-29-2016, 12:36 PM   #247 (permalink)
Nice work. It's sort of a T-arm instead of A-arm suspension? Why the heck not?
Edit: The software; could it lay out a dual traverse [airfoiled fiberglass] leaf suspension? With two pivot points instead of one to provide anti-roll?
orengomotors (06-30-2016)
Old 06-29-2016, 01:12 PM   #248 (permalink)
It's an T-arm because its strong enought ( 25mm diameter, 2mm wall) and adding another tube will make it heavier, the idea is to make an A-arm with smaller tubes to reduce unsprung weight on the future.
Are you referring to a dual wishbone system, but with leaf spring instead of shocksabsorvers, or to a dual wishbone where the wishbones are leaf springs?
The two are good ideas, and had been aplied to winner soapboxes on Spain.
Old 06-30-2016, 12:00 AM   #249 (permalink)
The latter. Like a Corvette leaf spring held at the 1/3rd points, but A-arm shaped. I found an article where something like it is discussed on a recumbent forum:
http://www.recumbents.com/forums/topic.asp?TOPIC_ID=6182
Old 06-30-2016, 02:36 AM   #250 (permalink)
on this, it has normal A-arms but with leaf spring instead of coilovers:
The Following 3 Users Say Thank You to orengomotors For This Useful Post:
freebeard (06-30-2016), Joggernot (06-30-2016), samwichse (06-30-2016)
aero, low drag, soapbox, streamlined
