02-09-2016, 06:46 PM
#241 (permalink)
But the Rumpler does pretty good with it.
04-04-2016, 05:28 PM
#242 (permalink)
Well after doing 2 races i can say that the front bodywork WORKS. Now i feel more the air into my face.
In the other hand i failed to make more roundish those edges  i only was doing ugly vents to the metal.
The Following 2 Users Say Thank You to orengomotors For This Useful Post:
04-04-2016, 07:53 PM
#243 (permalink)
Flying!
04-05-2016, 12:59 AM
#244 (permalink)
Heh. Loose straw on the track.
Somebody's been in the hay bales.
04-05-2016, 02:55 AM
#245 (permalink)
It's Downy soft!
06-29-2016, 12:21 PM
#246 (permalink)
The Following 4 Users Say Thank You to orengomotors For This Useful Post:
06-29-2016, 12:36 PM
#247 (permalink)
Nice work. It's sort of a T-arm instead of A-arm suspension? Why the heck not?
Edit: The software; could it lay out a dual traverse [airfoiled fiberglass] leaf suspension? With two pivot points instead of one to provide anti-roll?
06-29-2016, 01:12 PM
#248 (permalink)
It's an T-arm because its strong enought ( 25mm diameter, 2mm wall) and adding another tube will make it heavier, the idea is to make an A-arm with smaller tubes to reduce unsprung weight on the future.
Are you referring to a dual wishbone system, but with leaf spring instead of shocksabsorvers, or to a dual wishbone where the wishbones are leaf springs?
The two are good ideas, and had been aplied to winner soapboxes on Spain.
06-30-2016, 12:00 AM
#249 (permalink)
The latter. Like a Corvette leaf spring held at the 1/3rd points, but A-arm shaped. I found an article where something like it is discussed on a recumbent forum:
http://www.recumbents.com/forums/topic.asp?TOPIC_ID=6182
06-30-2016, 02:36 AM
#250 (permalink)
on this, it has normal A-arms but with leaf spring instead of coilovers:
The Following 3 Users Say Thank You to orengomotors For This Useful Post:
