04-06-2008, 01:12 AM
EcoModding Minded
Making my own A pillar pods, how should I adhere these?
Im making my own A pillar pod using the stock trim and wanted to see if anyone had any recommendations for adhering these to the trim to its bullitproof
I'll post up some more pictures for a FAQ on how I made this..
reason I'm making my own is because a company called lotek I purchased one from and the guages aimed outside toward the window..
not for me, so I make my own
mine is going to hug the A pillar closely..
So if you guys could give me some ideas of how to make this work the best, that would be greatly appreciated..
I believe the black plastic is ABS..
04-06-2008, 01:19 AM
I use Polyurethane for nearly everything, because it works with nearly everything, you can get it in black as well, I tend to get the black polly roof caulk, because it holds up to heat well.
04-06-2008, 05:01 AM
Liberti
If you want them removable, I'd figure out a way to bolt them from inside the trim piece.
If not, then I would use some of the left over epoxy from your tonneau project. Attach the pod with a fillet of epoxy and fiberglass tape, sand, paint, done...
P.S. I love watching all your projects. Your ability to get stuff done amazes me...
- LostCause
04-06-2008, 07:49 PM
EcoModding Minded
Thats sounds like it has some potential..
- LostCause
nah, fixed position is what i'm aiming for, a clean one piece look is what I like..
- LostCause
Thanks man, I couldnt have done it without the internet and search
Originally Posted by Daox
That turned out pretty darn good..
I like his results..
I'd like to figure out how to replicate texture too..
04-06-2008, 08:02 PM
This is actually my gauge pod project. Its a bit more involved so I didn't bother posting it. What I'm doing to keep the textured surface is using a wrinkle paint. Its not exactly the same texture as the rest, but its the closest I could find.
04-06-2008, 08:39 PM
EcoModding Minded
VERY NICE!! jet fighter cockpit style!
I was thinking for the texture you could use a build up primer and press a grainy section of leather against it while its tack.. Just an idea..
04-06-2008, 10:36 PM
EV OR DIESEL
IMHO Attach it however you need, then cover it with either fabric, vinyl, or leather.
A few pieces on the golf are sprayed with Spray on bed liner. works out OK, but not great.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
04-06-2008, 10:55 PM
#9 (permalink)
MechE
IIRC, you can buy texture paint...I believe it goes on like a primer
If you're going to paint (and not wrap with cloth).... Do try and avoid gloss paints... look for more of a satin or matte finish (buy some samples and try to match).... Nothing kills the aesthetics more than having one gloss panel when the rest have a satin finish
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
04-06-2008, 11:13 PM
#10 (permalink)
EV OR DIESEL
texture paint does go on similar to a thick primer, very dry. Bear in mind that it doesn't hide imperfections nearly as much as you would think.
Check out the Fabrication forum at MP3car.com for lots of ideas, but be warned they are the ones that convinced me a 15" tft would fit in a mkiii supra.
http://www.mp3car.com/vbulletin/fabrication/
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
